N series hydro pump output |
Post Reply ![]() |
WLHD21 ![]() Bronze Level ![]() Joined: 06 Feb 2019 Location: Iowa Points: 155 |
![]() ![]() ![]() ![]() ![]() Posted: 23 Feb 2021 at 11:24am |
Does anyone know the pressure and GPM on the gleaner Hydro pump?
DrAllis ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Points: 22087 |
Hydro pump or hydraulic pump ??
Hydro- transmission. I have a Vermeer trencher that has 75 cc pump at up to 6000# psi feed it. Looking for comparable pump to match the one on the trencher,
TramwayGuy ![]() Orange Level Access ![]() Joined: 19 Jan 2010 Location: Northern NY Points: 11780 |
“ Hydro- transmission. I have a Vermeer trencher that has 75 cc pump at up to 6000# psi feed it. Looking for comparable pump to match the one on the trencher,”
Just putting on a new pump is not the best approach. You have metal particles inside everything and they will rapidly take out anything introduced with out a thorough cleaning/filtering of the system. |
I cannot visualize what you're trying to do ?? Gleaner N-series hydros are a back-to-back pump-center section-motor all in one. You can't just take the pump out of it and do something. Buy the correct OEM parts and fix it right.
Post Reply ![]() |
