hb212 parts
coggonobrien View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote coggonobrien Quote  Post ReplyReply Direct Link To This Post Topic: hb212 parts
    Posted: 23 Feb 2021 at 7:53am
Going to be buying an hb212 with a briggs commercial 16hp already installed. Can somebody feed me part #'s for a new carb, plug and wires and also a reseal kit for the hydro?
Thanks!
Post Options Post Options   Thanks (0) Thanks(0)   Quote coggonobrien Quote  Post ReplyReply Direct Link To This Post Posted: 10 Mar 2021 at 8:29am
anybody?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 31 Mar 2021 at 12:20pm
Dave,
I can help ya with the tune-up and carb part of it if you have the B/S engine family no. off the tag. As for the wires, if you give me a length of what you need I can make one to the length needed.
Steve@B&B
Edited by Steve in NJ - 31 Mar 2021 at 12:22pm
ACmowerguy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACmowerguy Quote  Post ReplyReply Direct Link To This Post Posted: 03 May 2021 at 9:07pm
If the hydro is leaking around the pintle shaft it will likely need more than a seal kit. AC had a service bulletin out in the early '70s about boring and bushing the case. If you are lucky that may have already been done.  It is a Vickers T-66 pump.
Even after rebuilding mine there was a tiny leak.
