Shop ceiling choice advice? |
GSTROM99
Joined: 12 Dec 2020 Location: Greene, IA Points: 246 |
Topic: Shop ceiling choice advice?Posted: 19 Feb 2021 at 8:05am |
I'm doing all the normal research for my upcoming shop build. I'd been planning on using steel panels for the interior ceiling, but I just saw these PVC panels available through Menard's:
https://www.menards.com/main/building-materials/pole-barn-post-frame-materials/steel-panels/pro-tuf-interior-pvc-liner-panel/1558720/building-materials/pole-barn-post-frame-materials/steel-panels/pro-tuf-interior-pvc-liner-panel/1558723/building-materials/pole-barn-post-frame-materials/steel-panels/pro-tuf-interior-pvc-liner-panel/1558731/p-1535437692002.htm The PVC panels are slightly cheaper, and weigh about 1/5 of the steel panels. I'm leaning on going with these. Anyone have experience or opinions on the PVC option? |
steve(ill)
Joined: 11 Sep 2009 Location: illinois Points: 90793 |
Posted: 19 Feb 2021 at 9:57am |
never seen them before......... but looks REAL INTERESTING for a shop wall or ceiling !
jaybmiller
Joined: 12 Sep 2009 Location: Greensville,Ont Points: 25245 |
Posted: 19 Feb 2021 at 10:56am |
gives SugarChris yet another option to think about !!!! I like the less weight aspect....
Sugarmaker
Joined: 12 Jul 2013 Location: Albion PA Points: 8661 |
Posted: 19 Feb 2021 at 11:01am |
Dang you guys! I have my steel for the ceiling already but this stuff looks very interesting too. Thanks for the link. We have a Menards about a hour away in Ohio.
Regards, Chris
Dakota Dave
Posted: 19 Feb 2021 at 12:36pm |
For an 8' sheet that's all you can get in the poly a dura panel is 37 cents Cheeper and made of steel. I had poly panels for trailer skirting they did not hold up well. A lawn mower Rock whent rite through it shattered a piece out.I put the dura panels up on both my walls and cieling use the white it reflects lights wonderfully. I've backed a truck hitch thru the wall at the farm the steel is easy to repair just loosen it up bang it back our and stick a piece of gorilla tape on the back and screw it back in place. I put the galvanized ones up in my barn but they cause uneven lighting.
steve(ill)
Posted: 19 Feb 2021 at 12:55pm |
Dave, it says the poly is to be used INSIDE for ceiling and walls... I think being very LIGHT it might be a good ceiling cover.... and they list 8 , 12, 16, 20 ft lengths.
john(MI)
Posted: 19 Feb 2021 at 1:10pm |
If it's lighter weight wouldn't it sag between the joists!
SteveM C/IL
Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8981 |
Posted: 19 Feb 2021 at 8:57pm |
I'll keep my white steel (not so white after 35yrs) Never up there but if I missed my step, I'd still be up there not on the concrete floor
GSTROM99
Posted: 20 Feb 2021 at 9:27am |
Yeah, I've now decided to go white steel too. If the PCV was WAY cheaper, I would be more likely to try it. The brochure even says change in pigment (color) is expected and (only) has a 5 year warranty from cracking, etc... I don't want to have to re-do this. Ever. |
modirt
Joined: 18 Jul 2018 Location: Missouri Points: 9427 |
Posted: 20 Feb 2021 at 3:13pm |
So I'm finishing out a 12' x 24' enclosed shop inside the barn. It was roughed in when I got here, so has ceiling joists 16" on center. They run the 12' width and have about a 2:1 pitch. Walls and ceiling insulation is glass batts. Walls are covered with OSB. Was going to do OSB ceiling too, but now leaning towards doing this PVC or metal. PVC might not sweat.....and joists above are decked too, so not going to step on it. Would a person run that the long way, the short way or doesn't matter?
Dakota Dave
Posted: 20 Feb 2021 at 3:31pm |
I put reflected across my rafter bottom cords before putting the steel on blew in R 30 fiberglass above my shop stays warm in the winter and cool in the summer I have adequate attic ventilation so have zero condensation in a steel pole building.
jaybmiller
Posted: 20 Feb 2021 at 6:07pm |
re: Would a person run that the long way, the short way or doesn't matter? normally you run the 'next layer' of material 90* from the 'last layer'... consider a wall(easier for me), studs (1st layer) are vertical, so drywall (next layer) goes on horizontal.If you then added panelling, it'd go vertical..... clear as mud ??
steve(ill)
Posted: 20 Feb 2021 at 9:32pm |
modirt... normally you would run perpendicular to the joists... You have 12 ft joists on 16 inch centers and enough length for 24 ft.... You would buy two 12 ft pieces and put one on the end of the other to run 24 ft long... Your panels would be 36 inch, so you use 4 wide to fill the 12 ft room. ..... i did a little reading on the pvc panels and one thing is they act like siding on a house.. If it goes from zero to 100 degrees, the panels STRETCH and will bind on the screws... Some of the panels they recommend not squeezing the screws down REAL TIGHT... of course if you are inside and the temp only varies 20-30 degrees, probably not that important.
FREEDGUY
Joined: 15 Apr 2017 Location: South West Mich Points: 5396 |
Posted: 21 Feb 2021 at 3:40pm |
The 2- 12' panels doesn't allow for much overlap
steve(ill)
Posted: 21 Feb 2021 at 4:23pm |
dont need much... not raining inside the shop !
PVC panels are actually 12' 2" to allow for overlap. Edited by steve(ill) - 21 Feb 2021 at 4:25pm |
FREEDGUY
Posted: 21 Feb 2021 at 4:34pm |
I was thinking of the "fastening" aspect
steve(ill)
Posted: 21 Feb 2021 at 4:43pm |
why not ? you got a 24 ft room and two 12' 2" panels ... 4 inch overlap !
FREEDGUY
Posted: 21 Feb 2021 at 5:02pm |
Your original post said NOTHING about 12'2'' panels
!! Yes, now that you've modified your statement, it makes better sense.
steve(ill)
Posted: 21 Feb 2021 at 5:08pm |
but MOST IMPORTANT.... Did I get all the WORDS spelled right ? Edited by steve(ill) - 21 Feb 2021 at 5:08pm |
DMiller
Joined: 14 Sep 2009 Location: Hermann, Mo Points: 35664 |
Posted: 21 Feb 2021 at 6:19pm |
In my workshop I bought steel panels and used a modified drywall jack to bring up to the trusses. Had to order Ceiling rated truss to do this as the truss company stated if used in a Barn configuration are not designed for Weight carry underneath. These Were NOT Barn truss in my Shop, had same load rating as House free span ceiling carry truss.
