WD switch wiring
Matt Tallant View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Matt Tallant Quote  Post ReplyReply Direct Link To This Post Topic: WD switch wiring
    Posted: 15 Feb 2021 at 5:41pm
My 53 WD with a distributor
My key switch has two terminals
Anyone know what wire from harness, light switch goes to what terminal?
It is all original 6 volt and original key switch
Post Options Post Options   Thanks (0) Thanks(0)   Quote Matt Tallant Quote  Post ReplyReply Direct Link To This Post Posted: 15 Feb 2021 at 6:17pm
One terminal on switch is longer than the other
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 15 Feb 2021 at 7:35pm
Wire from ammeter to switch , switch to coil.              MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote Matt Tallant Quote  Post ReplyReply Direct Link To This Post Posted: 15 Feb 2021 at 8:13pm
Which one goes on the longest terminal?
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 15 Feb 2021 at 10:25pm
Don't matter.            MACK
Brian G. NY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian G.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 17 Feb 2021 at 8:58am
It doesn't matter in this case. In some cases, the "hot" side of the ignition switch is a good place to pick up power for accessories....hence, the longer terminal on that side of the switch.
