throttle controls on hd6ep |
giz's hd-6ep
Joined: 22 Aug 2010 Location: silver creek ny Points: 35 |
Topic: throttle controls on hd6epPosted: 06 Sep 2010 at 9:43pm |
howdy all i need some advice .got my hd6ep running ,but now i dont know how to run the throttle.It has a ground speed governor with a throttle lever on the left and one in the middle .It also has a pedal in the middle next to the throttle lever,they are all hooked up to the ground speed gov but none of them will move throttle on fuel pump.I have to rev up engine by hand down near cowl ,can somebody tell me what im doing wrong ???
DMiller
Joined: 14 Sep 2009 Location: Hermann, Mo Points: 35703 |
Posted: 07 Sep 2010 at 4:20pm |
Most times the pedal is not a accelerator but a DEcellerator, as to the rest of the controls hopefully Coke or one of the others can shed light.
giz's hd-6ep
Posted: 13 Sep 2010 at 7:37pm |
found my problem boys and girls . the previous owner repaired the lever with a piece of angle iron which was stopping the lever from coming all the way back .ground it down and all is good . other than the butcher repair job he did , will have to take lever off and fix right tho , no problem , vrooom vrooom
Coke-in-MN
Joined: 12 Sep 2009 Location: Afton MN Points: 42274 |
Posted: 13 Sep 2010 at 7:48pm |
Pat yourself on the back for a job well done . Fixing other peoples mistakes (former owners) can be a real pain.
giz's hd-6ep
Posted: 14 Sep 2010 at 8:55pm |
picture of ol girl in progress little blurry workin on better shots
BobsAc
Joined: 14 Oct 2010 Location: Lakeside, CA Points: 19 |
Posted: 14 Oct 2010 at 5:48pm |
I had an HD-6EP and had a lot of problems with the throttle/griund speed governor setup. Make sure the trans oil level is topped off, also that the screen in the bottum of the trans is clean... I actually did away with the decelerator pedal and made a direct throttle linkage down near the ground speed governor along with lengthening the throttle governor lever (short one on the left side) similar to what AC did on the later model ones... Mine was a 1965 model,s/n 18909.... Bob S.
giz's hd-6ep
Posted: 18 Oct 2010 at 7:33pm |
thanks bob .s getting ready to take her out for its first spin .probably will bypass decellarator since im only going to use around yard if all works out .been running it in garage up on blocks put a couple hours on engine and seems ok to take out . stack wont fit out door will have to do some mods .what do you prefer a curve stack or flapper ???.since i have to cut it off anyway or notch the door
BobsAc
Posted: 19 Oct 2010 at 7:02pm |
I really liked operating that HD-6, great little dozer, no problems other than those mentioned. I had a flapper on mine, but the later ones with the 7000 engines I believe came with the curved stack, at least I have seen pic's of that. I have 3 HD-6E's now, same except for direct drive. I'm probably going to part one of them out so let me know if you need anything that will fit off them. The HD-7G (early ones), used the 7000 engine and the same tranny/steering setup, different under carriage. So, potentially, another source of parts. Happy dozing! Bob S.
