D17 Series IV Hydraulics
Smeyer87 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Smeyer87 Quote  Post ReplyReply Direct Link To This Post Topic: D17 Series IV Hydraulics
    Posted: 09 Feb 2021 at 10:00pm
So I have a series IV D17 that I added a spool valve to for a second set of remotes to run a loader. Since installing the spool valve I have done nothing but fight the hydraulics. Currently it has started running oil out of both sides where the 3 point lift arms are, three point will only pick up occasionally and the pump sounds like the hydraulic fluid is cavitation. If I hold the three point lever to lift it just gurgle's and then will act like it catches fluid and will work. Theater won't do much of anything. I'm at a loss as I didn't have the leaks before this and now nothing is working properly. Any help would be much appreciated.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Smeyer87 Quote  Post ReplyReply Direct Link To This Post Posted: 09 Feb 2021 at 10:03pm
The loader won't do much of anything.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 09 Feb 2021 at 10:11pm
Sounds like it is low on hydraulic oil, number one. And number two, if you have leaks, you've done something wrong assembling the valve stack.  There are a certain amount of Oring seals between each section and the torque on the three tie bolts isn't that terribly tight. They must be snugged up gently a little at a time to get an even and equal squeeze on all three tie bolts.You did use new Orings ??
Post Options Post Options   Thanks (0) Thanks(0)   Quote Smeyer87 Quote  Post ReplyReply Direct Link To This Post Posted: 09 Feb 2021 at 10:16pm
Its not leaking at the valve stack it is leaking on both sides of the 3 point at the lift arms.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 09 Feb 2021 at 10:18pm
So, if it is leaking at the lift arm SHAFT, the transmission is OVERFULL with oil. The hydraulic oil dipstick is to the LEFT of the gearshift. You have added oil in the wrong hole ???
Post Options Post Options   Thanks (0) Thanks(0)   Quote Smeyer87 Quote  Post ReplyReply Direct Link To This Post Posted: 09 Feb 2021 at 10:34pm
I filled in the hole that has the threaded district to the left of the shifter. Not the push in district to the right.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 09 Feb 2021 at 10:37pm
The only reason the lift arm shaft can leak is because the transmission is overfull of oil. I still think you are low on oil in the hydraulics because they don't work right. That's what I think. I'm not there looking at it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 09 Feb 2021 at 10:40pm
Maybe you need to re-check both oil levels with the engine off and been sitting on level ground overnite. Leave that hydraulic fill dipstick very loose, so it can breathe air if it is plugged up, which it could be. How long have you owned this tractor ??
Post Options Post Options   Thanks (0) Thanks(0)   Quote Smeyer87 Quote  Post ReplyReply Direct Link To This Post Posted: 09 Feb 2021 at 10:58pm
Not long couple of months and not much history on it. It's been sitting for about 2 weeks so I can check it in the morning.
Joe(TX) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe(TX) Quote  Post ReplyReply Direct Link To This Post Posted: 10 Feb 2021 at 8:12am
Since you added a control valve, it may have something to do with how it is plumbed in.
Is it a power beyond valve?
Were is the return connected?
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 10 Feb 2021 at 10:19am
Is this valve bolted to tractor valve or is it a separate valve mounted somewhere else ? Sounds like you teed into pressure line. If so, that won't work.            MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 10 Feb 2021 at 10:48am
Well, I interpreted it to mean he added an extra A-C valve to the stack making it a four-outlet tractor on the rear plate. Maybe not. Still no real reason for this oil transfer problem on a real series four.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Smeyer87 Quote  Post ReplyReply Direct Link To This Post Posted: 10 Feb 2021 at 12:12pm
Yes I added another allis chalmers valve to the stack and bolted back into factory location.
Gatz in NE View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gatz in NE Quote  Post ReplyReply Direct Link To This Post Posted: 10 Feb 2021 at 12:54pm
When adding the valve to the stack, make sure that the small poppet valve and very light spring are in place before bolting it up.
And use the correct AC threaded rods for the assembly; don’t use
“redi-rod” or all-thread.  Neither are suitable.
The Dr is correct about the valve(s) not playing a part in the too-full situation.
Edited by Gatz in NE - 10 Feb 2021 at 12:56pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 10 Feb 2021 at 2:14pm
So, is the transmission overfull on oil and the hydraulics low on oil ?????
tbran View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 10 Feb 2021 at 6:24pm
If everything was ok til you added the extra valve - I 'm with Gatz - bet the valve did not have the pilot check and spring to go with it  - my 2 c worth.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 10 Feb 2021 at 8:40pm
I would agree about the pilot check.           MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote Smeyer87 Quote  Post ReplyReply Direct Link To This Post Posted: 10 Feb 2021 at 9:35pm
The check valve and spring are in there. Checked fluid level today and it is full. It acts like its just suckng air and not fluid. Maybe I need to replace the supply line to the pump.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 10 Feb 2021 at 10:21pm
But, what about your claim of dripping oil from the lift arm shaft ????
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 11 Feb 2021 at 8:44am
another thing -  your old seal on the pump drive shaft could have failed...  slightly pressurize the hyd compartment - slightly - with shop rag and blow tip air gun - if the pump works  - seal time.   But like Doc asks - the rear oil level is a puzzle..
Post Options Post Options   Thanks (0) Thanks(0)   Quote Smeyer87 Quote  Post ReplyReply Direct Link To This Post Posted: 11 Feb 2021 at 12:18pm
Where would I be pressurizing at the fill hole?
Kenny L. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kenny L. Quote  Post ReplyReply Direct Link To This Post Posted: 11 Feb 2021 at 4:30pm
Smeyer87, Do you have a smartphone? If you do snap some pictures of the valve stack that you change and were the oil is come out of the lift arm and you can text them to me if  you can't get them to upload and I'll post them for you. Hope this will help you. Kenny L.  five six three-920- two two 7 two
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 12 Feb 2021 at 10:07am
yes - just enough to prevent the pump having to suck up the oil . We  loosely wrap a rag around a blow gun and just barley tap the guns lever a couple of times.  If you over pressure the system you could blow a seal - but you would really have to  hold it to do that - if one has to use this method to prime a pump - there is a issue with the pump or supply lines/hoses.   Another thought - milky oil will cause the oil to foam - thus cavitation from the water dissolved in the oil.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gatz in NE Quote  Post ReplyReply Direct Link To This Post Posted: 12 Feb 2021 at 10:59am
The return line from the "stack" is still where it had always been, right?
A sudden leakage at the lift arms would indicate an over-full situation as the good Dr said.
In regards to the pump sucking air;
On D17sIV prior to s/n 76949, AC used a tube with a hose (pn 70242564) connection.
it's possible that air is getting in from it, especially if the hose clamps are not tight.
Effective s/n 76949, AC used an all-metal tube assembly.  If fittings are not tight, it could allow air in also.
Either arrangement still doesn't explain the leakage.
Edited by Gatz in NE - 12 Feb 2021 at 11:00am
LaJaMe View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LaJaMe Quote  Post ReplyReply Direct Link To This Post Posted: 15 Feb 2021 at 10:26pm
Make sure there is NO check valve ahead of the valves.  Had that happen to us.  Everything worked slow until we put the check valve after the valve levers.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gatz in NE Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jun 2021 at 9:52pm
so, what was the problem ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote LaJaMe Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jun 2021 at 9:52pm
Ours is a Model 200 industrial loader.  Front pump with the reservoir in the loader brackets and the levers plum bed in there.  We added and auxilary 2 double spool controls after the loader controls.  Rear hydraulics were about half speed.  Found that the relief valve at the loader controls was dumping fluid and pressure to the rear.  Plumbed it straight back to the rear and then to loader controls where it dumped back into the reservoir.  Hope this makes sense as I am doing it off my memory.  Works great so all the effort and though paid out.  The 17 handles the loader ( round bales @ 800-1000lb) and with 2 double and the normal single spool on the rear.  Might be one of a kind but we love it.
This page was generated in 0.053 seconds.
