AC B 12 volt conversion kit
Qvist View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Qvist Quote  Post ReplyReply Direct Link To This Post Topic: AC B 12 volt conversion kit
    Posted: 08 Feb 2021 at 1:40pm
Does anyone know where to get a 12 volt conversion kit and wiring harness for the 10si 3 wire alternator? ,I already have the alternator, alternator bracket and ignition coil. Tractor needs new harness with lights but I am unable to find a three wire version. Thank You
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 08 Feb 2021 at 2:26pm
For anything electrical the only place I go it the Brillman co.  www.brillman.com ;  Or you could call 1-888-274-5562  An tell them exactly what you need and they will make it specially for you with the wires you need for the alternator.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 08 Feb 2021 at 3:52pm
Steve at B&B would be a real good place to go......
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 08 Feb 2021 at 4:01pm
I would vote for Steve at B&B also!
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 08 Feb 2021 at 4:11pm
Scott B View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Scott B Quote  Post ReplyReply Direct Link To This Post Posted: 08 Feb 2021 at 4:25pm
Yep, Steve at B&B actually makes a little converter harness that snaps right into the alternator and then snaps into your wiring. He's helped me a ton and it's worth the money!
D17 Series 1
Allis B- 1939
Allis B- 1945
Post Options Post Options   Thanks (0) Thanks(0)   Quote Qvist Quote  Post ReplyReply Direct Link To This Post Posted: 08 Feb 2021 at 8:15pm
Thank you, I will check with these suppliers.
