Wd 45 shifter |
D14JIM14
Bronze Level Access
Joined: 25 Jan 2020 Location: Brazil, indiana Points: 190 |
Topic: Wd 45 shifterPosted: 08 Feb 2021 at 9:49am |
I took the gear shift tower off this 45 which as I posted before has set 30 + years and won't shift. Gears and forks and end of stick all look real good !
But I can't slide the forks and shafts they are on . I guess I'll tear it down and clean and lube the detents and shafts etc . |
IBWD MIke
Joined: 08 Apr 2012 Location: Newton Ia. Points: 4285 |
Posted: 08 Feb 2021 at 12:28pm |
D14JIM14
Bronze Level Access
Posted: 09 Feb 2021 at 2:08pm |
Thanks Mike !
I'm using PB Blaster and getting the shafts to move with a rubber hammer . I hope time PB and patience will keep me from a tear down . Gears , shifter , and forks look real good ! Jim |
Sugarmaker
Joined: 12 Jul 2013 Location: Albion PA Points: 8662 |
Posted: 09 Feb 2021 at 3:49pm |
Jim,
The shift lever has a lot of leverage on moving these forks. Is that how you have it set up out of the tractor? So you can use the shift lever to move the forks? I assume the actual gears will move on the shafts in the transmission? Regards, Chris
MACK
Posted: 09 Feb 2021 at 8:43pm |
only one rail will move at a time. With all rails in nutual, move one , then back to nutual, then move another. MACK
D14JIM14
Bronze Level Access
Posted: 09 Feb 2021 at 9:07pm |
Thanks Mack
