D17 leaking power director lever shaft |
Post Reply ![]() |
Bob (mo) ![]() Bronze Level ![]() ![]() Joined: 22 Nov 2009 Location: Missouri Points: 140 |
![]() ![]() ![]() ![]() ![]() Posted: 06 Feb 2021 at 10:30am |
working on a series 1 D17. I need to replace the seals on the power director shifter shaft (both sides) I have never done it before but from what I read on here from an older post it doesn't sound too difficult. Are the o-rings in a groove on the shaft or in a groove in the case? Any pointers anyone can give will be much appreciated.
DougG ![]() Orange Level ![]() Joined: 20 Sep 2009 Location: Mo Points: 8356 |
Maybe check out Agcoparts- thyey usually have a good pic of things
johmor15 ![]() Bronze Level ![]() Joined: 25 Apr 2018 Location: ocala fl Points: 6 |
be careful not to slide the shaft out to far on either side or you might lose the keyways in the shaft that operates the power director clutch just did my d 19 took about 15 min
orings are in the shaft
jlogli ![]() Orange Level ![]() Joined: 12 Oct 2011 Location: Stockport, IA Points: 862 |
I always have a little compressed air and blow everything off make sure it’s free dirt. Lube your O-rings up a little bit before sliding back in to housing
1945 WC on full steel, WD wide front, WD45 power steering, 1966 D-17IVfactory 3 point.1967 D-17IV SC. 1973 rotobaler white top. orange top roto, model 90 combine,82S, four bottom plow.302 baler.
DrAllis ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Points: 21905 |
On an old D-17 of that age, you'll have to remove the cover on the right side and remove the setscrew on the inside that retains the clutch fork. There are no keys on this tractor. After the hand lever is removed on the outside and the setscrew removed on the inside, you can slide the shaft back and forth an inch to replace the Orings.
Got it all done it was a simple job thanks for all the helpful advice.
Post Reply ![]() |
