Vehicle Oil Change Interval ??
FREEDGUY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Topic: Vehicle Oil Change Interval ??
    Posted: 05 Feb 2021 at 5:54pm
This is on an '05 5.4 Ford with conventional oil/Motorcraft 820S filter. Can I "stretch" the 3000 mile interval if I've got to add a quart and a half between (I've stretched it to 3500 miles since I've owned it) oil changes to 4,000 miles ? Thanks
Edited by FREEDGUY - 05 Feb 2021 at 5:55pm
Jim.ME View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim.ME Quote  Post ReplyReply Direct Link To This Post Posted: 05 Feb 2021 at 6:02pm
3000 miles sounds like your own interval.  What does your manual say?  Most went to 5000miles/6 months before '05 I believe.
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Posted: 05 Feb 2021 at 6:09pm
Thanks for the reply, seems like the 5000 was for synthetic Confused .
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 05 Feb 2021 at 6:18pm
I run 5000 miles on everything.. Have since 1970..   The "NEWER" cars say 7500 miles in the manual.. I would not do that unless i was on the highway and adding up quick.. 5000 is a real good interval for most everything on Conventional oil.
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Posted: 05 Feb 2021 at 6:26pm
Thanks guys
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim.ME Quote  Post ReplyReply Direct Link To This Post Posted: 05 Feb 2021 at 7:13pm
5000 for Conventional, synthetic claimed it would go longer.
FloydKS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote FloydKS Quote  Post ReplyReply Direct Link To This Post Posted: 05 Feb 2021 at 8:06pm
Light comes on at 3,000 so I go two lights worth...
Stan IL&TN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stan IL&TN Quote  Post ReplyReply Direct Link To This Post Posted: 05 Feb 2021 at 9:29pm
I ignore the miles and change it in the spring and fall when the weather is nice with synthetic oil.
1957 WD45 dad's first AC
1968 one-seventy
1956 F40 Ferguson
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hubert (Ga)engine7 Quote  Post ReplyReply Direct Link To This Post Posted: 05 Feb 2021 at 10:35pm
In my '99 5.4 I run the Motorcraft synthetic blend and change at 5,000 mile intervals; 242K on the clock now. A lot of the service centers still add 3,000 to the odometer reading and it gets them more business.
john(MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote john(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 06 Feb 2021 at 1:33am
On my 2000 I changed it every 5000 on the thousand, so when it was xx0,000 or xx5,000, I would change it. easy way to tell when it is due. I used conventional in it.  On the 16 It changes at every 10.000 miles so that's an easy number to remember too.  It uses full synthetic.
fixer1958 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote fixer1958 Quote  Post ReplyReply Direct Link To This Post Posted: 06 Feb 2021 at 4:57am
02 Chevy 6.0 synthetic blend every 3-4K
Dave H View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave H Quote  Post ReplyReply Direct Link To This Post Posted: 06 Feb 2021 at 7:36am
I think we got some old school thoughts here.  As I recall my 2012 Ford is 7500 with the blend.
NOW the wife's Toyota goes 10,000 or one year and it has a lifetime power train warranty.
Oh yeah, Ford always puts a 3000 sticker on the windshield.  LOL
Edited by Dave H - 06 Feb 2021 at 9:47am
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 06 Feb 2021 at 7:51am
I had access years ago to oil sample analysis so used it, My '99 F250 7.3 diesel ended up at 5k intervals Religiously to when slowed usage became twice a year REGARDLESS spring and fall.  Oil looked great as drained as may have only had 1800-3000 miles but acids build up and filtration does NOT remove or stabilize.  Moisture buildup from sitting is the WORST for production of acidity on oils.  My later autos have a built in miles against driving aspect calculators, our Exploder runs on average 4800 miles between as get to 30% remainder oil life, my Pimpala goes closer to 5500.  Tractors are still generally twice per year both the last 7G and the 180 as well the little Deere Diesel mower.
The LP GMC had two oils changes while it lived here, one as bought it and one after rebuilt it as LP delivers next to no carbon to the oil pan.  LP is dry and tends to not draw as much acid to the oil pan for some reason.  I did start it at least monthly and run it around to keep fluids circulated.
Tbone95 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 06 Feb 2021 at 9:15am
3000 miles for turbo charged gasoline engine
5000 miles most everything
Go by the monitor on vehicles so equipped.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 06 Feb 2021 at 12:05pm
The thing to look for when going over on oil changes intervals is how thin the oil actually gets - the manufactures have there specs along with oil, everyone bitches when the auto transmisions go out, but  because no one pays attention to the manufacture specs on oil changes,,  just my experince
Edited by DougG - 06 Feb 2021 at 12:15pm
Lars(wi) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lars(wi) Quote  Post ReplyReply Direct Link To This Post Posted: 06 Feb 2021 at 12:21pm
We wait for the onboard computer to indicate when an oil change is needed.
On the Ford Explorer is will be approx. 5-6,000 miles
On the little Honda CRV with 4 banger it will be before 5k.
Wife used to have a Chev Impala, that would trip at just under 10,000 if using Mobil 1. If using any other brand of synthetic oil it would trip at about 8,500.
My old Suburban with the TBI(no fancy puter) , get done every 5,000
all vehicles use full synthetic oil.
Joe Goodwill View Drop Down
Bronze Level Access
Bronze Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe Goodwill Quote  Post ReplyReply Direct Link To This Post Posted: 06 Feb 2021 at 12:39pm
Nephews mother in law had an early 90’s? Bonneville. They stopped changing oil at 180k, hood seized at 240k so no fluids added or checked and drove til about 340k. (All miles)
I change diesel 7.3 trucks at 5k or spring and fall if not enough miles.
180 and 185’s annually, not regular use anymore.
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Posted: 06 Feb 2021 at 4:58pm
Apparently you don't put many miles on your buggy ??
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Posted: 06 Feb 2021 at 5:00pm
OUCH !! $$$
Post Options Post Options   Thanks (0) Thanks(0)   Quote fixer1958 Quote  Post ReplyReply Direct Link To This Post Posted: 06 Feb 2021 at 6:04pm
If you are doggy Chevy, that's fine.
LeonR2013 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LeonR2013 Quote  Post ReplyReply Direct Link To This Post Posted: 06 Feb 2021 at 6:32pm
I change both my T/C's at 3,ooo M. My son who is an ace mechanic recommends the 3,000 m, intervals and use the oil that is is recommended by the car company. And the better oil filter you use is very important.       Leon
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stan IL&TN Quote  Post ReplyReply Direct Link To This Post Posted: 06 Feb 2021 at 8:12pm
I change the wife's Camry, daughters Camry, daughters Buick Regal and my 94 Chevy truck.   So much easier to drag all the oil change stuff out at the same time. I do record the mileage and you are correct my truck might average 3000 between changes. Wife's car is around 6000. Other two about 5k. This works for me.
1968 one-seventy
1956 F40 Ferguson
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Posted: 06 Feb 2021 at 8:15pm
Thanks for the reply Stan, makes sense on the multiple vehicle oil changes .
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Posted: 21 Feb 2021 at 3:31pm
Jim, I had 2 other people + myself scour my OM for the "maintenance schedule" oil change interval, it AINT in it WinkWink !! The info was in dads '11 F250 manual though Confused.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave H Quote  Post ReplyReply Direct Link To This Post Posted: 21 Feb 2021 at 5:10pm
Leon, ask your son about the Toyota program.  Our Highlander is changed at the 10K or one year interval, and that is with a lifetime power train warranty.  Shocked
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pat the Plumber CIL Quote  Post ReplyReply Direct Link To This Post Posted: 23 Feb 2021 at 8:31pm
06 Chevy 1500 express van with 4.3 V6 . Service van that is rode hard and put up wet . Every 3000 miles , black as coal .05 Chevy Siverado 2500 HD 6.0 V8 . Mainly highway miles on weekends , every 5000 miles and still is brown . Van has 380,000 miles and the truck has 180,000
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 23 Feb 2021 at 8:43pm
my tractors had oil and filter changes every 100 hours, my vehicles get both changed every 2000 miles.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stan IL&TN Quote  Post ReplyReply Direct Link To This Post Posted: 23 Feb 2021 at 9:33pm
I
The wife's last two Toyotas had this but I thought 10k miles was too many so I would change it at 5k then Toyota changed it at 10k and then me again at 15k and them at 20k. We tag teamed it.
1968 one-seventy
1956 F40 Ferguson
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave H Quote  Post ReplyReply Direct Link To This Post Posted: 24 Feb 2021 at 7:39am
shameless, if I lived by you I could run your used oil and still be changing it out at 4000.
You are gonna be in deep doo doo if Sleepy catches you wasting crude.  Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 24 Feb 2021 at 7:47am
2000 miles?  Wow....how many months is that, is that why?
