D15 II Crank End Play
Dave H View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave H Quote  Post ReplyReply Direct Link To This Post Topic: D15 II Crank End Play
    Posted: 06 Sep 2010 at 6:07pm
set the crank in the 15 II block today.  End play was 2 to 3 thou.  That is tight according to the manual but she spins freely.  I think I am good to go with that.
what do you all think?
Pete from IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pete from IL Quote  Post ReplyReply Direct Link To This Post Posted: 06 Sep 2010 at 6:14pm
When the motor gets hot the parts expand and the clearance gets smaller. I would go with what the book says. What is the clearance supposed to be?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave H Quote  Post ReplyReply Direct Link To This Post Posted: 06 Sep 2010 at 7:07pm
my book says 4 to 8
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 07 Sep 2010 at 11:59am
I sure wouldn't worry about it....use 5W-20 or 5W-30 for break-in oil and you'll be fine if it truly has .002" to .003" which is enough room for oil to squirt thru.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave H Quote  Post ReplyReply Direct Link To This Post Posted: 07 Sep 2010 at 12:34pm
thanks Dr Allis.  Yep I measured it a bunch of times and got the same thing.
