53 AC WD45
AhYooper View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AhYooper Quote  Post ReplyReply Direct Link To This Post Topic: 53 AC WD45
    Posted: 05 Feb 2021 at 10:05am
Hello.
First time posting but have read alot in these forums that has helped me with my new (old) tractor already. I bought this about 8 months ago and it ran great,still does to some extent. One thing it started doing is surging,like the throttle is going up and down until it eventually stalls. It usually starts this after it gets worked,like when I was pushing dirt over the summer,pulling heavy logs or now,pushing snow. Once ya dog the engine a little and the govenor kicks in,it seems to fall apart shortely therafter. If I shut it off and walk away,in a half hour or so,its good to go again,until ya dog it out a lil and it starts surging again. I am fairly certain after reading info I found on these forums it has to do with the govenor. I am just hoping that one of you more knowledgeable tractor people can confirm my suspicions (as best as one can over the interweb) so I don`t waste time and money replacing the wrong part.
I can tell its gonna start cause the idle starts to get a tiny bit rough than I know its time to get off and give it a lil break. I am a shade tree mechanic,rebuilt small blocks and done quite a bit of wrench turning,building and trouble shooting but never with tractors.
This is a 53 AC WD 45. It started life as a 6volt but the gentleman I bought it off of said it was converted to 12 volt and showed me a resister and explained a couple other things about that. He did mention that the govenor was sometimes sticky,but at the time I didn`t know what that meant and since it ran great I dismissed it to the back of my mind. For the first couple months I never had any issues until I started  pulling logs for my firewood pile. Than more when I would push dirt and now snow.
So any advice to my tractor problem would be greatly appreciated. Many thanks for any advice I can get.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 05 Feb 2021 at 10:21am
Running out of gas. Fuel flow inadequate. Not the governor.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AhYooper Quote  Post ReplyReply Direct Link To This Post Posted: 05 Feb 2021 at 10:28am
Really.
One thing I noticed on the carb is it does get condensation going on the outside of it when its cold out,prolly normal just wanted to mention that.
I know when its starting to idle rough,if I slide the trottle up to increase the rpm,that just makes it worse. It runs best on low idle. Now that ya mentioned that, the gas thing does make alot more sense.
Maybe I`ll pick up a new fuel filter and start the process of elimination.
Thanks DrAllis. This would not have been the first time I tried to take the long road to the wrong way. Exactly why I wanted to check with you guys first! Smile
Edited by AhYooper - 05 Feb 2021 at 10:42am
LouSWPA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LouSWPA Quote  Post ReplyReply Direct Link To This Post Posted: 05 Feb 2021 at 11:22am
To expand on what Dr Allis says, you need to start with the gas tank. Take it off, drain it and inspect the interior, they have a habit of rusting and the rust eventually clogs filter, and carb. a lot of guys use various methods of knocking the rust loose and then using a gas tank liquid liner to seal it. If you don't seal it, at least knock all the loose stuff off and clean it out real well.
In any case, what ever you decide to do with the tank, clean the gascolator, and I use an automotive inline filter from NAPA between the gascolator and the carb. and finally, you will need to rebuild the carb. It probably has junk in it causing the float to stick, or clogging passages
I am still confident of this;
Wait for the Lord;
Post Options Post Options   Thanks (0) Thanks(0)   Quote AhYooper Quote  Post ReplyReply Direct Link To This Post Posted: 05 Feb 2021 at 11:46am
The gas tank definitely has some rust issues on the inside. The guy gave me a small old bucket he used to keep upside down on top of the gas tank,he said  to keep water from getting under the cap on a windy rainy day.I clean the glass bowl every time I run it,always has 1/8 inch of sediment in it.  Fuel filter probably weighs 2 lbs by now lol. He put a new one on it right before I bought it,but I used it alot over the summer and it did slowly degrade on the running good side. Seems so obvious now.
Thanks for the intel guys. Feel like I dodged a bullet goin after the wrong part first! I know what I`ll be doing on my next day off.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 06 Feb 2021 at 9:53pm
You might also want to get one of these.  I've put them in ALL of my tanks.  They help tremendously!  https://www.yesterdaystractors.com/cgi-bin/store/model_parts.cgi?SearchArea=Allis-Chalmers&&md=CA&cat=Fuel%20System%20/%20Air%20Intake&r=mcats
Allis Chalmers CA Fuel Tank Screen
Fuel Tank Screen
- This Fuel Tank Screen is used with most stem-type sediment bowls to further protect against debris in the gas line. It has a 0.216 inch Insert Pipe outside diameter (7/32)- 2.53 inch Overall Length. Outside diameter of screen is 0.375 of an inch. If the Insert (7/32) is too large, you can use a 7/32 drill bit to enlarge the hole in the fuel filter assembly. If the insert is to small, use foil to shim. (Part No: R7949)
$9.90
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 07 Feb 2021 at 6:47am
Welcome! Congratulation on the WD series tractor!
rw View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rw Quote  Post ReplyReply Direct Link To This Post Posted: 07 Feb 2021 at 7:34am
I have a tractor that would act about the same as you are saying.  I kind of thought it was something in the fuel delivery to the carb and finally found the rubber tip on the needle valve had become swollen. Seemed like longer periods of operation would make it die and not restart till it cooled. If I did a 15 or 20 minute job no problem, plenty of power etc. I finally proved this by taking the plug out of the bottom of the carb after it died and gas barely dripped out, but I had good flow out the gas line going into carb. I suspect ethanol or some other thing that came in some gas or just age caused it. Been fine since.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AhYooper Quote  Post ReplyReply Direct Link To This Post Posted: 07 Feb 2021 at 1:08pm
Just came in from a frosty 1o degrees out there with some great news. Thanks to the great advice to look at a fuel problem, I did exactly that. I took the sediment bowl assembly out of the bottom of the tank,caught most of the gas to run it thru a coffee filter later and inspected the sediment bowl assembly.
You guys were spot on. To my amazement,it was much more than rust flakes and debris. I pulled a lil twig about an inch and a half long out of it and more branch debris inside the fuel outlet. Wood! I`m like, how the heck did WOOD get in there?! Either way I was pleased to see those obstructions. My gasket was shot to the bowl but I had a sediment bowl assembly for a ford 8n here I originally bought to fix my bosses tractor that I swapped the bowl and gasket and retainer to see if all was well. Slapped it back into the tractor put one gallon of gas back in it and boom. Started right up and ran like a top again.
I am going to totally go thru and do the tank right along with a new sediment bowl assembly that isn`t half Ford and get it done right when the weather is more appealing. Just happy to have my snow plow back up and runnin great again. I did replace the fuel filter. Once it warms up to some balmy 20's gonna git r dun!
Heres a pic. Think I got a great deal. Picked it up for $2300 with the loader and a plow blade. Guy said it was resleeved 20 years prior to me buying it along with a new clutch. I would ordinarily scoff at that kind of statement but it was literally parked for 15 years and kind of forgotten about since his wife couldn`t drive it w/o power steering. He had a newer Ford they used and once the barn he stored this tractor in was needed for other things, he chose to sell it rather than store it outside. He was an older gentlemen and seemed believable. The thing runs awesome and already paid for itself by gettin 3 culverts ut in and about 30 yards of gravel moved and the pasture cleaned and 15 cords of wood pulled up front. LOVE it!
Just wonder why it took me till 47 years old to think....."I should get a tractor" lol Best money I ever spent.
Again, thankyou very much for all the info. I am sure you haven`t seen da last of me =)
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 07 Feb 2021 at 3:07pm
Good looking Tractor! Yes they will still do some work!
DaveKamp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 08 Feb 2021 at 1:15pm
There ALSO may be a catch screen in the inlet fitting to the carbeurator... even if your machine wasn't equipped with one originally, someone MAY have swapped carbs or fittings, and if it's a bit plugged up there, it'll restrict your flow substantially.
A fuel tank cap that isn't venting can cause similar headaches, yours is most likely debris in the plumbing.
Ooops, posted that too late!  LOL
Glad you found it...
Re  'How'd the WOOD get in there?
It GREW there, of course!!!  LOLLOLLOL
Edited by DaveKamp - 08 Feb 2021 at 1:18pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote LouSWPA Quote  Post ReplyReply Direct Link To This Post Posted: 09 Feb 2021 at 10:23am
my guess on the twigs in the tank, checking the fuel level, with whatever was handy! pick up a stick off the ground........
Wait for the Lord;
IBWD MIke View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 09 Feb 2021 at 1:12pm
Done that a hundred times! Or a thousand.
