Zenith carb
DCAC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DCAC Quote  Post ReplyReply Direct Link To This Post Topic: Zenith carb
    Posted: 03 Feb 2021 at 4:07pm
What's everyone's experience/opinion on the Zenith carb on a 170?  Are they better/worse than the M-S on a 175?  How about parts availability comparison? Has anyone put the 175 carb on a 170, and if so, what needed to be changed to make it work?  Thanks for any input!
FREEDGUY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Posted: 03 Feb 2021 at 5:07pm
I'm now curious as to why you think 1 "might" be better than the other Confused ?? I can't believe that parts aren't readily available for either carb Smile .
DCAC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DCAC Quote  Post ReplyReply Direct Link To This Post Posted: 03 Feb 2021 at 5:44pm
Well, a couple reasons, I don't have any experience with a Zenith carb, I need a new main jet needle assy., and I haven't seen it offered anywhere either.  Saw a couple on ebay, but not sure if they are correct.  Haven't tried NAPA for this yet.  Also wondering why they put the M-S on the 175, is it a bigger carb than the Zenith?  M-S more reliable?  More questions than anything right now is all.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 03 Feb 2021 at 6:48pm
The Marvel is technically larger because it flows more air. Why they didn't use a larger Zenith ?? I don't know. Can't answer you that one, Bunky.
AC7060IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC7060IL Quote  Post ReplyReply Direct Link To This Post Posted: 03 Feb 2021 at 9:05pm
This is a web link to napaonline.com from a Brookings, SD Napa store for a 1968 AC One-Seventy zenith carb kit priced at $44.99
Hope this helps.
https://www.napaonline.com/en/p/BK_S66443?partTypeName=Carburetor+Kit&impressionRank=1&keywordInput=carburetor
DCAC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DCAC Quote  Post ReplyReply Direct Link To This Post Posted: 04 Feb 2021 at 9:10am
Thanks for the replies and the link, Gentlemen!  Alex09 has a needle assy., so I'm going to put the kit in that I already have and try it out.  This tractor sat for a long time and the inside of the bowl is pitted, I had it cleaned in an ultrasonic cleaner as well, so will see how it works.  I see ASAP and YT both have rebuilt Zenith carbs for sale, but haven't dealt with either on carbs, anyone have experience with this?
WF owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 04 Feb 2021 at 1:25pm
There are several vendors that support this site that will have carburetor kits priced competitively.
DCAC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DCAC Quote  Post ReplyReply Direct Link To This Post Posted: 05 Feb 2021 at 4:04pm
Just a heads up for anyone else using the NAPA kit in the above link, it is not correct for the Zenith 13294 carb on the 170.  Hopefully not stepping on anyone's toes, that's not the intention.  Just trying to save someone else the hassle of finding out the hard way is all.
Fred in Pa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fred in Pa Quote  Post ReplyReply Direct Link To This Post Posted: 05 Feb 2021 at 4:15pm
I have kits ,floats n main adjusting needle jet for them .
nonetheless ,still dead.
DCAC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DCAC Quote  Post ReplyReply Direct Link To This Post Posted: 05 Feb 2021 at 4:19pm
Would you have a new throttle shaft?  That's part of the reason I thought I'd try the NAPA kit as it had a new throttle shaft in it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 05 Feb 2021 at 4:50pm
A 170 carb throttle shaft is unique to a 170 Zenith carb because it is mounted backwards on the engine.
DCAC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DCAC Quote  Post ReplyReply Direct Link To This Post Posted: 05 Feb 2021 at 5:02pm
The throttle shaft on this one is worn, but maybe it'll be good enough to get the tractor to run.  Engine was stuck when I got it, have since gotten it loose, along with a couple stuck valves.  The carb must've sat with fuel and water in it too, as it's pitted some in the bowl area, main jet needle was rusty and pitted too.  Hopefully the rest of the tractor turns out good when I get it back together.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fred in Pa Quote  Post ReplyReply Direct Link To This Post Posted: 07 Feb 2021 at 12:47pm
I have a local guy make the shaft , put the leaver off old one on new shaft.
This page was generated in 3.227 seconds.
