7040 trans into 8050
Gary(WI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary(WI) Quote  Post ReplyReply Direct Link To This Post Topic: 7040 trans into 8050
    Posted: 06 Sep 2010 at 4:37pm
Found a 7040 powershift trans that is good wondering what if any modifications I wouls have to do to put it in a 8050 powershift is there different gear ratios or they all the same through the years his trans only has 2nd gear and is leaking oil out of the front seal     Any help will be greatly appreciated   Gary Roidt  920 253 8192
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary(WI) Quote  Post ReplyReply Direct Link To This Post Posted: 07 Sep 2010 at 3:14pm
Can anybody help me on this how about drallis
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary(WI) Quote  Post ReplyReply Direct Link To This Post Posted: 07 Sep 2010 at 6:10pm
Does anybody have atrans out of a 8050 or similiar to sell must be powershift
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 07 Sep 2010 at 6:19pm
Unless it's a late model 7040, the rear clutch pack bolts that retain the gear are 3/8" diameter.....I'd hate to use it in an 8050FWA, but it should fit and work without a problem. Use the valve off of the 8050..much better design. All gear ratios in the PST are the same. Take a look at the way the FWA side frames bolt to the front of the bellhousing under the oil pan on the 8050......there might be a couple holes that a 7040 doesn't have??? look and be sure.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary(WI) Quote  Post ReplyReply Direct Link To This Post Posted: 07 Sep 2010 at 10:44pm
Thank You very much this tractor is a 2 wheel drive so bolt size should not be a problem
