Solar Panel Site
modirt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote modirt Quote  Post ReplyReply Direct Link To This Post Topic: Solar Panel Site
    Posted: 02 Feb 2021 at 9:42am
Have noticed a curious bit of construction going lately. Turns out it is a solar panel site.....situated on about 5 acres of land.....but not just any land. It is land that fronts to an I-70 access road about 1 mile east of the city limits of Columbia. Land that may be valued somewhere in the range of $20k to $30k per acre. Not sure how that scours as best use of the land when if the same thing were moved 5 miles down the road, where sun shines the same, land cost would be half that or less.
But what seems curious to me is the construction. Panels are about 12' wide, but are separated by open driveways, each also about 12' apart. Presumably that is for access to get to the panels to service them, but why not simply elevate the panels and drive under them? That way you double up the surface area of the panels to double output on same amount of expensive land?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 02 Feb 2021 at 10:57am
Need to be able to walk between them to Wash Them.  Not good enough to just spray with a water cleaning solution, HAS to be cleaned rinsed and SQUEEGEE'D to remove any possible contaminates that will impede delivery.  Next problem of them revealed, HAVE to be cleaned RELIGIOUSLY at least monthly, some regions WEEKLY.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 02 Feb 2021 at 11:00am
This is AMEREN's test project Solar, aside O'Fallon MO on Google Maps.  Has a PERMANENT staff of five to keep them cleaned and maintained as weather affects them OFTEN.  1.1mw at Full capacity, roughly 5 hours per day.  Which BTW it is now a MAJOR embarrassment to the Upper Echelon expense wise(Five times fossil per kwh).
Edited by DMiller - 02 Feb 2021 at 11:08am
AC7060IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC7060IL Quote  Post ReplyReply Direct Link To This Post Posted: 02 Feb 2021 at 11:17am
Maybe the wrong application for the dusty Midwest?
tadams(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tadams(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 02 Feb 2021 at 12:27pm
I seen a solar farm in Flordia a couple years ago when we went driving past it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 02 Feb 2021 at 12:31pm
also those panels are HEAVY... The access road is to drive a bucket truck and crane between the rows to install / remove panels as needed ( new or damaged).
HaroldOmaha View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HaroldOmaha Quote  Post ReplyReply Direct Link To This Post Posted: 02 Feb 2021 at 7:56pm
These things are known to fry a lot of birds flying close over them.
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 02 Feb 2021 at 8:00pm
state of IA has several solar sites along the interstates, they take up the room that would usually be waste ground for the state, said they power the rest areas.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 02 Feb 2021 at 9:19pm
I have not seen anyone clean the ones all around our area.
One big site was put in and after one winter they all frost heaved and were falling over. Wounded who paid for that mistake
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 03 Feb 2021 at 4:41am
Originally the sites I have witnessed around MO were well attended, now they seem to be left to nature almost in a I Told You So move to prove they are a foolish game.  Previous employer was given Truck Loads of Grant money to fund research projects of Wind and Solar generation.  More fodder to the Big elites pocketbooks.  Solar cells on the Home office building roof downtown STL barely are able to keep backup DC Systems for the computers functionally charged, and cover the entire building roof.
allisbred View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote allisbred Quote  Post ReplyReply Direct Link To This Post Posted: 03 Feb 2021 at 5:19am
This is a very sore subject where I live just outside of Gettysburg pa. Several thousand acres of farm land is dedicated to solar fields now. Zoning was changed, hidden from residents while it was happening. The fields will supply power for Philadelphia which is several hundred miles away from here. The contractors will only be responsible for ~20 years of maintenance and then my guess will go under at the end of the term. Vegetation grows fairly rapid due to the amount of rain and I would think needs to be sprayed frequently. The local residents are not being told how this will be handled. I keep trying to way it out in my head if I’d rather see houses or solar fields— only protection I guess is to own the land myself which is not possible.
Edited by allisbred - 03 Feb 2021 at 5:21am
ac fleet View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac fleet Quote  Post ReplyReply Direct Link To This Post Posted: 05 Feb 2021 at 4:06pm
They are trying to put that chit in our neighbor hood,--- they had contracts for a couple hundred acres,---now one of these sites ( 160 some acres) is going up for auction and IF it sells-- company will have to deal with new owner and if he tells them to hit the road----then they are out ----construction would still be 5+ years away so nothing built yet, or even set only on paper so buyer has the option as to which way to go.
Now they are hunting for other sites and so far no takers. ----solar is a rip-off and waste of taxpayers dollars.
Dorix View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dorix Quote  Post ReplyReply Direct Link To This Post Posted: 05 Feb 2021 at 4:18pm
  The Dutch/Czech gov'ts found that wind/solar requires between 148x-536x more land than nuclear and would cost 4x more. roadtoclimateneutrality.eu
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 05 Feb 2021 at 6:25pm
Now they are hunting for other sites and so far no takers. ----solar is a rip-off and waste of taxpayers dollars.---
Everything has a place and time... Normally that is determined by COST and EFFICIENCY.. You still cant beat COAL or NUKE.... Maybe in 5 years ?  10 years ? ...........What I see with SOLAR is it can be used by small business or individuals, unlike COAL which takes a POWER PLANT... When they get the COST DOWN for SOLAR where you can install on your house and payback in 4-5 years with a 15 year life, then its TIME HAS COME.
Edited by steve(ill) - 05 Feb 2021 at 6:27pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 07 Feb 2021 at 8:06pm
Local zoning prohibits solar farms , you can have your own residential on limited buildings but no large arrays on property . Then i see the next township has allowed a couple on farm lands but only small acreage areas .
 Son has a contract to make some pulling attachments for a solar company where they have to replace the stands the arrays set on as once erected they cant get large equipment in to replace the posts if damaged and needed something small to work around existing units . His puller fits onto skid loader for easy access .
Post Options Post Options   Thanks (0) Thanks(0)   Quote allisbred Quote  Post ReplyReply Direct Link To This Post Posted: 08 Feb 2021 at 12:25pm
Just keep an eye on who’s on that zoning board! Things can change very fast! I thought much like you that I was safe in a farming community. I also thought “OC” for “open country” sounded good... lol.
Edited by allisbred - 08 Feb 2021 at 12:28pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac fleet Quote  Post ReplyReply Direct Link To This Post Posted: 09 Feb 2021 at 12:38pm
YUP! money under the table rules the world!
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 20 Sep 2023 at 6:19am
The ones here my previous employer has installed took up to two years to site prep and construct, the largest is just at 2mw at Peak delivery(around hour and a half per day of good sunshine) and yet took a small town sized piece of ground where cannot deliver more than a subdivision worth of power at Peak. Millions spent and at per mw costs around five times what a base load plant can provide.
dr p View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dr p Quote  Post ReplyReply Direct Link To This Post Posted: 20 Sep 2023 at 8:45pm
In new york state they are going up all over. Little different economic situation. None of the pasture ground has any value and we certainly can't grow 250 bushels corn or 100 bushel beans. So a lot of guys who are struggling are taking the money. I think there may be a place for them here if you are willing to take the money now and wait for total corporate screw job in the future.
HudCo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 20 Sep 2023 at 10:01pm
they are doing one whole section of ground by me and trying to lease two more sections of farm ground for them ugly looking things not to happy about that
orangeman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote orangeman Quote  Post ReplyReply Direct Link To This Post Posted: 05 Oct 2023 at 7:18am
Solar panel farms are being built here in the U.S. due to the Feds and State providing subsidized loans and grants - ( i.e. our tax dollars) to prop up the industry!  Much like many other subsidized programs.   Follow the money and see!
Orangeman
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 05 Oct 2023 at 7:54am
local power company (CO-OP) built a small wind mill 10 years ago.. When people questioned it, i remember the Manager saying... "Well the FED is paying 50% and the State/ Local are paying another 20%.. and that makes it ALMOST economical".. Clap
Tbone95 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 05 Oct 2023 at 9:17am
My biggest by far landlord retired from farming 3 years ago, slowed down some the 2 years before that. He’s taking away 92 acres from me and having solar panels installed. He’s taking away 100’s from others as well. Sort of blows my mind that someone like him, family legacy of farming around here of well over 100 years is “almost permanently” taking productive, flat, square, drained, accessible land out of agriculture like that. My own personal losses aside, very sad to see. Money talks.   Farm activity can’t compete with the solar fad on the same economic level.
