D10/D12 Traction Booster Gauge
jollymon68 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jollymon68 Quote  Post ReplyReply Direct Link To This Post Topic: D10/D12 Traction Booster Gauge
    Posted: 01 Feb 2021 at 9:09am
Trying to find out if one of my D12's was suppose to have a traction booster gauge or not. I have a D10 serial# 9234 and another D12 serial# 5789 and they all have one. The D12 serial# 10027 does not and cannot see if it ever had one. All three tractors have a factory 3pt. hitch. How can I tell if this one is missing or never had one.
Thanks
Charlie175 View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 01 Feb 2021 at 9:15am
Does the Gauge Panel hole have a blank over it? Or another gauge is there?
By then I'd imagine they all came with one. All "D" series I have seen had one.
Charlie
JoeM(GA) View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote JoeM(GA) Quote  Post ReplyReply Direct Link To This Post Posted: 01 Feb 2021 at 3:18pm
Looking at the online parts, the first ones didn’t have them, then went through two changes if you look at the serial number breaks in the right column
Allis Express North Georgia
41 WC,48 UC Cane,7-G's,
Ford 345C TLB
Matt Tallant View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote Matt Tallant Quote  Post ReplyReply Direct Link To This Post Posted: 01 Feb 2021 at 3:21pm
Our D-10 has it serial 3950
Post Options Post Options   Thanks (0) Thanks(0)   Quote jollymon68 Quote  Post ReplyReply Direct Link To This Post Posted: 01 Feb 2021 at 9:12pm
No blank there but this D12 dash has been apart a few times.Figure ill just put one in that doesn't function. None of the gauges are original, but it does have the tach and it works. The wiring was so jacked up i replaced it with aone wire harness, new plugs, cap, rotor, coil, new gauges, and coil. Now i cant get it to start even with starting fluid. Got spark and the carb has been rebuilt completely. got me stumped! Been tackling this for hours, time to step away and rethink.
Post Options Post Options   Thanks (1) Thanks(1)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 02 Feb 2021 at 6:50am
Check your plug wire order. Sounds like they are out of order maybe?
1243 is right
Charlie
This page was generated in 0.477 seconds.
