AC 816 Backhoe Parts
Gavineg123 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gavineg123 Quote  Post ReplyReply Direct Link To This Post Topic: AC 816 Backhoe Parts
    Posted: 31 Jan 2021 at 12:12pm
Where is the best place to look for backhoe parts? For example gauges, starter, transmission, and hydraulic parts? Also, best place to buy engine parts? It’s a Perkins inline 4 cyl. Any help is appreciated
gemdozer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote gemdozer Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jan 2021 at 1:30pm
You could check with MINNPAR
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 01 Feb 2021 at 5:36pm
the AC 816 used a AC engine  from my knowledge , the 715 used a Perkins 236 - 4 cylinder
Jim.ME View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim.ME Quote  Post ReplyReply Direct Link To This Post Posted: 01 Feb 2021 at 7:48pm
816 and 816B parts books at Minnpar show Perkins.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gavineg123 Quote  Post ReplyReply Direct Link To This Post Posted: 01 Feb 2021 at 8:02pm
I’ve got a service manual for it and it shows a Perkins 4.248 engine
Eric B View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eric B Quote  Post ReplyReply Direct Link To This Post Posted: 02 Feb 2021 at 12:17pm
So many parts for the 816 are found in and on other industrial equipment. Therefore it helps to search the brands on each component rather than searching for '816 parts' as direct listings are simply harder to trace being they were made around 40 to 50 years ago. Like the starter for example if you get the number off of it you will have a much easier time tracking a replacement or individual parts. You can find gauges that fit but they may no have the AC logo on them. The forward reverser is a Borg Warner, the rear end is Rockwell, the hyd. pump is a Commercial Shearing, the engine being a Perkins 248 is not hard to find parts for as they were widely used in many applications.
david a View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote david a Quote  Post ReplyReply Direct Link To This Post Posted: 14 Feb 2021 at 3:46pm
had a hard time finding the steering pump. The shuttle is a WG. not a borg werner hard to find parts for. I rebuilt mine the forward clutch is hard to come by. The engine is a Perkins. The main hydraulic pump is a expensive one to rebuild. The shift cable is hard to come by. I sold mine last year for $5500. just got tired of the scavenger hunt. and the expensive parts.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eric B Quote  Post ReplyReply Direct Link To This Post Posted: 15 Feb 2021 at 11:42am
What model year was your 816? The two I had were made in 1970 and they both had Borg Warner forward reverser.
Post Options Post Options   Thanks (0) Thanks(0)   Quote david a Quote  Post ReplyReply Direct Link To This Post Posted: 16 Feb 2021 at 8:01pm
think mine was a 1975.  and It was a werner gear shuttle . Had very big clutch plates.
Norris1606 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Norris1606 Quote  Post ReplyReply Direct Link To This Post Posted: 23 Nov 2025 at 4:39pm
do you have any information on the steering pump/steering orbital?  I just bought an 816 and the steering orbital has a crack in the housing.  so far, Ive not found any numbers stamped or any tags on it.  Thanks!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 23 Nov 2025 at 11:32pm
The orbital should interchange with many other tractors
AC used most parts from other suppliers rather than being AC only built .
 Starter motor is Delco though I just replaced mine from a Amazon supplier 10 tooth drive and full new unit was $140 - I had rebuilt mine 3 times over the years and have cracked 2 nose cones on the Delco units
Post Options Post Options   Thanks (0) Thanks(0)   Quote Norris1606 Quote  Post ReplyReply Direct Link To This Post Posted: 24 Nov 2025 at 4:44pm
I figured the orbital would interchange, just not sure where to begin with not having any tags or stamped numbers on it.  I was hoping someone had some info on the orbital as far as manufacturer or what it might interchange with.
