Combine Bearing Replacement ?
FREEDGUY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Topic: Combine Bearing Replacement ?
    Posted: 29 Jan 2021 at 6:25pm
There's a post on AT about bearing checking/ replacement on the separator side of a machine (the guy is looking at a JD 9600) and a respondent said 2000 hours was the "replace/trade off" time frame for his operation Ermm . I really thought bearings lasted a little longer than 2000 hours Embarrassed ?? What have you guys experienced with bearing longevity ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jan 2021 at 7:20pm
80% of all bearings fail due to lack of lube / dirt.
another 10% fail due to miss alignment / install damage.
VERY FEW fail from being overloaded or end of life.. Most bearings are DESIGNED to run longer hours.
I cant speak for that SPECIFIC bearing, but in "GENERAL", ........
Ag equip is designed for 5,000 hours ... ( some applications could be half that)
light duty cars / trucks are designed for 2,500 hours
industrial equip ( factory) is designed for 20,000 hours
Edited by steve(ill) - 29 Jan 2021 at 7:36pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jan 2021 at 9:57pm
alot of combine bearing fail because the owners/operators power wash them.
JPG AUSTRALIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JPG AUSTRALIA Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jan 2021 at 12:20am
Steve is spot on ๐Ÿ‘ A bearing will last for nearly ever if it has clean grease and not misaligned,... and no water๐Ÿ˜€.
Edited by JPG AUSTRALIA - 30 Jan 2021 at 12:23am
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jan 2021 at 5:12pm
I have no issues with the replies that Steve posts on the equipment/shops-barns-vehicles sections  and I have great respect for them,Wink !! He's a straight shooter in those regards !!!
GM Guy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GM Guy Quote  Post ReplyReply Direct Link To This Post Posted: 07 Feb 2021 at 5:17pm
Depends mostly on lube and load. we rarely rear walker shaft bearings, but usually end up replacing left fan shaft bearings on L/M series.
On machines stored outdoors, a shot of teflon infused penetrating oil really helps to limber up an old bearing.
Gleaner: the properly engineered and built combine.
If you need parts for your Gleaner, we are parting out A's through L2's, so we may be able to help.
Krazy Karl View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Krazy Karl Quote  Post ReplyReply Direct Link To This Post Posted: 07 Feb 2021 at 7:00pm
All depends on maintenance. Maybe guy had bad experience once and in his mind replacement during off season is better than down time during harvest.
CrestonM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 13 Feb 2021 at 10:00pm
Would that help only if the seals were bad?
