816 backhoe shifting
Gavineg123 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gavineg123 Quote  Post ReplyReply Direct Link To This Post Topic: 816 backhoe shifting
    Posted: 29 Jan 2021 at 6:08pm
I just bought a AC 816 backhoe and curious how to get it to shift? I moved forward and back just fine. Put new transmission oil in it but it doesn’t seem to want to shift out of first gear. Open to any suggestions.
Eric B View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eric B Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jan 2021 at 1:43pm
If your machine has been well used, the linkage going from the shifter to the top of the transmission often becomes loose enough that the gears don't respond, I had it happen to mine although not on first gear I don't believe. I'm sure you'll see what needs doing once you look at it with the floor plates off.
david a View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote david a Quote  Post ReplyReply Direct Link To This Post Posted: 14 Feb 2021 at 3:52pm
loose linkages
