A/C A816
Gordy53 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gordy53 Quote  Post ReplyReply Direct Link To This Post Topic: A/C A816
    Posted: 29 Jan 2021 at 9:28am
I just bought an A/C 816 we got it started on starter fliud but will not keep running
Checked fuel filter is full
There is how ever a wire by ignition S/W that is not connected could this be for the on/off fuel solenoid any thoughts
Jim.ME View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim.ME Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jan 2021 at 11:28am
I would start by using a test light or voltmeter to see if there is power at the shutoff when the key is on, before just hooking up loose wires.  If there is no power, I would next try a jumper wire to power the shutoff.  I might try using a jumper to power the loose wire and test to see if it did power the shut off, before hooking it to the switch.
  If the machine has been setting for a time there may be issues (things stuck) inside the pump, that starting it hasn't improved.
gemdozer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote gemdozer Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jan 2021 at 12:24pm
Did you check if the trottle rod is connected
Eric B View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eric B Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jan 2021 at 1:51pm
Every 816 I've seen has mechanical fuel shut off, if it is still mechanical on this be sure the shut off lever on the pump is in the 'moved forward position'. You may also need to check if the primary pump on the side of the block is putting out pressure. On my 816's I bypassed the primary pump and only operated them on gravity feed as the tank is so high up.
david a View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote david a Quote  Post ReplyReply Direct Link To This Post Posted: 14 Feb 2021 at 3:49pm
Mine 816 had a cable fuel cut off .  you could convert it to a solenoid. Likeit was stated make sure the fuel shut off is forward
