CA Rear End
KP View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KP Quote  Post ReplyReply Direct Link To This Post Topic: CA Rear End
    Posted: 06 Sep 2010 at 1:13pm
I replaced all the bearings in the the final drives of my CA, however within a few weeks the bearing on the ends of the axles were out again. The axles appear to have too much end play. Is there a retainer ring on the axle somewhere that keeps it from moving in? I think this is what needs replaced, but I'm not sure how to get to it. Any ideas?
Dick L View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 06 Sep 2010 at 1:50pm
The bearings on the axle is set with the stud on the inside bearing by adding or removing shims. Located under the cap.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 06 Sep 2010 at 3:10pm
If you replace any tapered roller bearing, you need to reset clearances in the bearings. Timken type bearings will run loose, but will not last long at all if they are too tight. Tolerances are close for diameters and race finish but the overall stack height will vary.
This page was generated in 0.172 seconds.
