6.00 - 16 Tires
Mike ( WI ) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mike ( WI ) Quote  Post ReplyReply Direct Link To This Post Topic: 6.00 - 16 Tires
    Posted: 06 Sep 2010 at 10:25am
Does any one have any old 6.00-16 tires lying around ? reason is I have this real old wagon which have this size tires on but they are rotted bad, I need 4 total the tread is no big deal as long as the tires are not rotted out, so I can just move this wagon around, not going to load anything on it or anything just to move it around the farm.
Thanks !
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 06 Sep 2010 at 10:29am
might be easire to find some truck tires , 7.50 X 16 or so than those early 6.00 X 16 tires.
Other thing might be to find rims and tires in 15" size
Faith isn't a jump in the dark. It is a walk in the light. Faith is not guessing; it is knowing something.
"Challenges are what make life interesting; overcoming them is what makes life meaningful."
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 06 Sep 2010 at 10:48am
I think 6-16 (rim width designation) changed to 6.50 or 6.70-16 when the width designation went to the maximum tire width. They will be bigger but many a pickup with 16" rims used things like 215 R 16 through 245R 16 and there are many of those lying about. I'm sure I have a couple sets in the barn waiting for hay rack use that's not going to happen. Taken off because of too many cracks for safe road use.
I've not found used car tires on machinery to last well, especially outside. They are only expected to last 5 years and sometime after that they literally fall apart.
Gerald J.
pumpkin man View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote pumpkin man Quote  Post ReplyReply Direct Link To This Post Posted: 06 Sep 2010 at 11:17am
     go to a tire store (discount Tire ) or Firestone  thay send most take offs to a re
cycler. tell them as long as they are round & black & 16 " & hold air youl takem 2 or 3 diffent  sizes on a wagon dosnt  mater
