416 electric lift
Mike K View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mike K Quote  Post ReplyReply Direct Link To This Post Topic: 416 electric lift
    Posted: 23 Jan 2021 at 9:26pm
How do you test the switch. Power on both sides. What makes it send power to the cylinder to reverse movement
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jan 2021 at 10:51am
My first guess is it would reverse polarity? I’m not familiar with that model but if it’s a electric lift that’s my best guess.
HudCo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jan 2021 at 3:32pm
you have two solionds that switch the power also uses a 6 terminal momentary on off on switch i have two little tractors with electric lift
Gatz in NE View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gatz in NE Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jan 2021 at 10:36pm
simply put, something like this.....
there would be just 2) wires used on the linear actuator
Edited by Gatz in NE - 29 Jan 2021 at 10:40pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mike K Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jan 2021 at 5:43am
Thanks.
 Sandylake has new ones
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mike K Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jan 2021 at 5:54am
Need actuator. Does any know the torque needed. I purchased one from Amazon and does not enough zip
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jan 2021 at 6:20am
re: I purchased one from Amazon and does not enough zip
Ok, what are the specs for that one ?
'not enough zip' ? you mean it's too sloooooooow or won't lift ?
lifts but too slow is a motor RPM issue.
I've 'cheated' in the past,boosted the 12v to 24 for extra speed....
won't lift is a 'ft-lbs'  issue,
you need a greater lifting actuator.
usually 'they' trade off 'lift capacity ' for 'speed', and viceversa so you need to read the specs. You can get high ft-lbs at high speed for more  $$$ though.
as a rule of thumb, the greater the AMPS draw, the more it'll lift.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gatz in NE Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jan 2021 at 11:44am
Not familiar with a 416, but I'm guessing the factory lift has a high force rating, and therefore relatively high amperage draw.  A common DPDT switch would not be able to handle the load, hence the solenoids or relays.
Is yours like the one being taken apart in this OLD thread?
or, what is wrong with the one you have?
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jan 2021 at 12:26pm
does this help....
if it's it, simple DPDT center off 12vdc switch for the up-down. it 'reverses' power to the lift motor. Newer 'linear actuators' have built in 'limit switches' to prevent 'bind up'.
if replacing it, figure out what the implement weighs(say 200#) then buy unit>200ftlbs.
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jan 2021 at 7:48pm
you need the solind s sothat you can use use big enought wires and have a duty cycle  that will move it fast and not burn up the switches my cf struck set up that way and also my jd 112
