correct spark plugs for a B with a distributor |
Post Reply |
Thad in AR.
Orange Level Access Joined: 12 Sep 2009 Location: Arkansas Points: 9535 |
Posted: 06 Sep 2010 at 8:38am |
I would like to know what plugs and gap to use on a 6 volt B with a distributor?
countryguy828
Bronze Level Joined: 11 Sep 2009 Location: Arcanum, Ohio Points: 129 |
I used Autolite 295's in my CA with distriubtor as per reccomendation from Steve at B&B.
Dave
Steve in NJ
Orange Level Access Joined: 12 Sep 2009 Location: Andover, NJ Points: 11899 |
The 295's are a little bit hotter plug which work much better in worn engines. Some folks use the 303's for Distributor fired Tractors. They work fine also providing the engine is pretty fresh, where oil control is in check and compression is up to the norm.
mlpankey
Orange Level Joined: 13 Sep 2009 Location: Vols country Points: 4580 |
ngk b6s
Steve in NJ
I've tried the NGK B6S plugs in my machines also. They worked quite well. No fouling, and burned pretty nice....
mlpankey
I goofed a b4 is the equivalent to a ac 45 or autolite 295 . the b6s is equivelent to the ac44 or autolite 303.
Post Reply | |
