looking for cotton picker
allis1221G View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote allis1221G Quote  Post ReplyReply Direct Link To This Post Topic: looking for cotton picker
    Posted: 21 Jan 2021 at 8:11pm
looking for a older smaller cotton picker. not sure if they made a pull type or not.
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jan 2021 at 8:16pm
Allis Chalmers made a 1 row unit to go on a CA.
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jan 2021 at 7:19pm
Allis....gits ahold of Creston on this site...he can tell you all about them, maybe he knows where you can get 1?
JohnColo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JohnColo Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jan 2021 at 12:18am
There's an Allis 880 for sale on Big Iron, sells on Jan 27, current bid $300.  In Anthony, KS
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jan 2021 at 7:34am
those are strippers. He is looking for a picker I think. Very different machines.
Post Options Post Options   Thanks (0) Thanks(0)   Quote allis1221G Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jan 2021 at 4:06pm
did not know there was a stripper or picker. whats the difference?
CrestonM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jan 2021 at 4:50pm
A picker picks the lint off the plant, leaving the burrs and leaves behind. A stripper strips everything off the stalk, conveys it into the machine, and separates the lint from the burrs, sticks, and leaves via a burr extractor that is somewhat similar to the way a cotton gin works. In my area of southwest OK, cotton strippers were always used. You'd be hard pressed to find an old picker of any make, but Allis 860 and 880 strippers are everywhere. A lot are scattered about western Texas as well.
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jan 2021 at 5:53pm
A picker is a much more complicated machine, with rotating spindles on drums, and is typically used where it doesn't get cold enough to kill off the foliage. The stripper uses simple brushes to remove the cotton fibers from the bare plant usually after it has been cold enough to kill the foliage. AC pickers were mounted on reversed modified tractors, JD & IH as well initially. Later models of IH and JD went to dedicated component chassis, like a combine. The Cotton stripper is on a component chassis as well.
