333 No-Til Coulter
JimWenigOH View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JimWenigOH Quote  Post ReplyReply Direct Link To This Post Topic: 333 No-Til Coulter
    Posted: 17 Jan 2021 at 6:43pm
I'm in the process of repurposing some no-til coulters and need to remove everything from the yoke hub. There is a dowel pin locking the arm assembly to the yoke hub. So far I'm not having any luck removing that pin. The pin protrudes about 3/16" on top and is flush on bottom. I've been trying to press it back out the top side. Is that correct? Does the hub need heated first?
tbran View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jan 2021 at 7:34pm
Well it has been in there about 40 years... we always set them on a iron anvil then applied a sledge hammer to a punch in a large slip joint pliers held by a trusting low man on he totem pole.....  really tough to get in a press and yes heat to the housing does help.  When you get it out , before installing that new piece of gold torsion spring, grind off the point end on a 45 degree down about three quarter inch so it will twist and line up the hole when it is driven back in.  The assy is preloaded and the hole will not line up with out a hassle. This trick works great - make sure the round male piece moves easily and doesn't have to be driven in as in remove the paint.
Post Options Post Options   Thanks (0) Thanks(0)   Quote JimWenigOH Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jan 2021 at 8:10pm
Thanks for the information Tim. The only part I have any doubts about is whether my wife will agree to hold the pliers. I've only got 6 of these to do.
rw View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rw Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jan 2021 at 8:27pm
I had to do several and used an air hammer with a punch bit.
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jan 2021 at 5:45pm
did you get a stimulus check to cover the costs? :-)  I used my mother in law for years until her fingers ran out...   and ,, these are about $230@ ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote JimWenigOH Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jan 2021 at 7:33pm
Thanks for another good idea. Wife said no to holding the pliers, so I'm going to look at the pawn shop tomorrow for a chisel or pointed tip that I can cut off flat to try driving it out after heating the housing.
Post Options Post Options   Thanks (0) Thanks(0)   Quote JimWenigOH Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jan 2021 at 7:46pm
Too late for the mother in law, lol. Actually I won't be using those rubber shocks any more, I just want the stripped hub and shank to use on a project. I had heard the shocks were pricey.
automaticdave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote automaticdave Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jan 2021 at 7:53am
Did any other manufactures or machinery companies use that rubber coulter spring or was it exclusive to only Allis, Dave
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jan 2021 at 2:04pm
exclusive to AC - used on plow coulters, cultivator stabilizers, no til coulters and ground drive fertilizer tension suspension. 70350380 $230.00   but they last 40 years - during that time springs, bushings and pivots would eat  up a lot of that as in field cultivator pivots.
8070nc View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8070nc Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jan 2021 at 4:11pm
Where do you get the rubber coulter springs now that are any good. I bought 2 from agco for a 3000 model plow and it seperated and fell off on the first pass
1984 80780
1957 D14
DES 300 with 25000 engine
616 tractor
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jan 2021 at 7:49pm
they are warrantied for a year!  They ALWAYS had a few bad, nothing new.  You got lucky to have 2 haha
