shop florescent light layout
Mrgoodwrench View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mrgoodwrench Quote  Post ReplyReply Direct Link To This Post Topic: shop florescent light layout
    Posted: 15 Jan 2021 at 6:30pm
this year i finally got around to building a garage/shop at home. the electricity should be in next weekend so now i have to decide how to lay out my lights. shop is 30 x40 with 12ft ceiling. i have a bunch of 4ft florescent shop lights that i want to use and convert to led. i think i have at least a dozen fixtures. how would you lay the out? there are 3 bays with doors on the 40' wall.
There are 3 ways to do job GOOD, FAST, CHEAP. YOU MAY CHOOSE 2. If its FAST & CHEAP it won't be GOOD, if it's GOOD & CHEAP it won't be FAST, and if its GOOD & FAST it won't be CHEAP!!!!
john(MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote john(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jan 2021 at 7:05pm
I'd put them in down each side of each bay and across the front.  Get smart plugs and connect each bay to one plug.  Name the bays, like bay 1 ,2, 3, Then program alexa to turn on or off whichever bay you want or turn on all.  Add lights wherever else you need them and identify them to alexa.  You can even have her turn on the tv.  The 4' single bulb led are super bright.  You can plug two together to make 8' foot lights.  Put up osb sheathing for the ceiling and paint it white before the lights go up.  It will add significantly to the brightness.  I don't know what the price is on smart receptacles but the little round plug in smart plugs are probably a cheaper way to go.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jan 2021 at 7:10pm
Why take old lights and convert to LED... You can buy 60 or 100 watt equiv screw in bulbs for $1. each ........ i just buy the  elect box and sockets and install at 6-8 ft intervals.. You can have a couple switches to turn on front- back.. or  1-2 bays if you dont want all the lights on at the same time.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jan 2021 at 7:41pm
hmm..if I read it right , you've got 3 bays, each about 13 x 30.
Get some 1/4" square paper and draw a 'bay' out.each square is 1' x 1',easy for me to see... Now split into 6 'sections',6.5x10 squares. fill in a 1x4 rectangle(4 squares) centered in each 'section'. This represents a light fixture.So there will be grid of 6 fixtures at grid positions 4-5,4-15,4-25,10-5,1-15 and 10-25. It'll make more sense when you draw it out, believe me. It's a LOT easier to try again on paper than up-down a ladder all day !!
Yes ,I know it's  a lot of lights,  I have 10 in my 24 x 24 garage, still not enough.
It really helps to have the ceiling and walls painted white. Each 'bay' should be on a separate switch. I replaced the original 'one lightbulb' base with a quad receptacle box. two lights get plugged into it,so I can easily add 1 or 2 more. Also if one unit fails, I can just unplug,remove, install another in minutes..NO rewiring necessary !
Now if you buy high brightness ( 10K lumen) units , you won't need as many.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mrgoodwrench Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jan 2021 at 7:52pm
several of the fixtures have bad ballasts. it is cheaper to convert than to replace and i like the instant on and cheep running
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jan 2021 at 8:02pm
YEP... i ment instead of using the OLD CASES, i just go to screw in LED bulbs... i just question why hang old cases in a new construction.... If you really want to use 4 ft lights, i agree, it is normally cheaper to modify the old cases as compared to buying new  4 ft cases. ...
i upgraded to LED a few years ago... at that time the 4 ft kits were $30.  so i scrapped the 4 ft cases and just installed boxes and LED bulbs... when one goes out it cost $1. to replace.
Edited by steve(ill) - 15 Jan 2021 at 8:16pm
plummerscarin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote plummerscarin Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jan 2021 at 8:07pm
This is my 30x40 with 12ft ceiling. You can see the 4ft fixtures set end to end. I am very happy with the amount of light in here. The ceiling tin was reclaimed and haven't finished the white paint yet but still plenty bright. Sorry for the mess.
Stan IL&TN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stan IL&TN Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jan 2021 at 8:29pm
You will need more fixtures. You can't have too many in my book. My shop is just 16x24 and I have 10 fixtures. Half led and replacing the other half as they die.
1957 WD45 dad's first AC
1968 one-seventy
1956 F40 Ferguson
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jan 2021 at 8:30pm
Just put a couple 4 foot LED's in the sugarhouse kitchen. Must say they are very bright! Replaced a 8 foot florescent.
Good luck with your new lighting layout. I need to watch this too as my shop will need lighting at some point too!
We need pictures of your shop!
Edited by Sugarmaker - 15 Jan 2021 at 8:30pm
fixer1958 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote fixer1958 Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jan 2021 at 8:53am
I bought 6-4' shop lights on Amazon for $100. Same kind Menard sells only a few bucks cheaper to replace the ones in my garage. Gotta look down when you turn them all on because it's so bright. Seeing stuff in there now I didn't want to see and things I haven't for years.
tadams(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tadams(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jan 2021 at 9:02am
6 Pack LED Shop Light 4FT, T5 Integrated Single Fixture, 22W, 2200lm, 6500K Super Bright White, Linkable Shop Light, Utility Shop Lights, Corded Electric with Built-in ON/Off Switch
Amazon'sChoicefor "6 pack led shop lights"
Price:$40.99 Prime FREE Delivery & FREE Returns
Dave H View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave H Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jan 2021 at 7:21am
Steve, I stopped by the local Menards on the way home last eve and picked up a box of leds like you posted.  You guessed it, they were on the shelf on the floor.
Best deal in town.  thanks for posting
