What machine used this part?
TomYaz View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TomYaz Quote  Post ReplyReply Direct Link To This Post Topic: What machine used this part?
    Posted: 09 Jan 2021 at 6:06pm
Number in casting is SG-252L...
Very similar to something used on the Rotobaler.  A have also larger version with a better number that was used on moldboard plow (??? thats what the master parts catalog says!!) and a Field cultivator.....
Stan R View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stan R Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jan 2021 at 6:20pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote TomYaz Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jan 2021 at 6:35pm
Originally posted by Stan R Stan R wrote:
I have no idea if this is it but the sg-252L turned up in the search
I searchd to and cam up with a archived snippet saying "Don't know what kind it is has # LTP 180 on hub & another # SG252L "
The link to that snippet is gone.. I bet it is referencing that same pic and it goes on that plow..  But what the heck would that part be doing on that plow???
Post Options Post Options   Thanks (0) Thanks(0)   Quote TomYaz Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jan 2021 at 6:36pm
But then again, I have a larger version of the part that my book says goes on a plow!!
Fred in Pa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fred in Pa Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jan 2021 at 6:43pm
Part of the trip lift
nonetheless ,still dead.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TomYaz Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jan 2021 at 6:54pm
I see....thats a big hunk of metal for that!
Thanks All!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jan 2021 at 11:22pm
yeah, it's kind of like a ratchet.  As the wheel turns, a piece of cog slides into the path of the cut outs and then you can see where it would push against the lip until it had to slip into the next one.  I hope that explanation works for you?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jan 2021 at 11:31pm
what’s the other side look like Tom
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fred in Pa Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jan 2021 at 7:45am
Mike , Just flat n round.
DWC17 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DWC17 Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jan 2021 at 8:35am
Tom, from what I see in my plow book and on my plow, part # SG252L is the inner clutch on a #1 plow. The center hole should be 1 1/2" diameter for the axle to go through. The # N-297A is the hub cap for the same plow. # LTP-180 is a clutch throw out arm on a # 1 plow. You said you have another piece that is larger and if the number is SG 257L then it is the inner clutch for a #2 plow. The hole in the larger piece would have to be a larger diameter for the larger axle. I am looking for part # 300729 which is the outer clutch for a #2 plow. It would have 2 ears stick out 180 degrees from one another.
Dan
jiminnd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jiminnd Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jan 2021 at 8:36am
like  Fred said, part of lift, plow or cultivator or similar.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TomYaz Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jan 2021 at 12:25pm
ok guys, the flip side per request
This should answer some guess...
The bigger part is part number 315024
Post Options Post Options   Thanks (0) Thanks(0)   Quote TomYaz Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jan 2021 at 1:02pm
BTW I have the LTP-180 too.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fred in Pa Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jan 2021 at 1:25pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote TomYaz Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jan 2021 at 1:30pm
Thanks Fred !
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jan 2021 at 2:00pm
My hernia hurts just THINKING what them 'things' weigh......
1947WC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 1947WC Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jan 2021 at 3:28pm
Maybe  off a wc?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fred in Pa Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jan 2021 at 3:52pm
If you read all above ,its a plow part , Jay what makes u think these small parts weight so much. LOL
 Here is Plow my parts in above picture came off of .
Edited by Fred in Pa - 10 Jan 2021 at 4:07pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jan 2021 at 5:15pm
re: Jay what makes u think these small parts weight so much.
maybe I'm just getting old......sigh....
I STILL can't find my battery carrying handle gizmo, it HAS to be IN the garage,it ws there when I put 2 batteries in the forklift a month ago
maybe I'm just getting old......sigh....sigh....um...
Jay
This page was generated in 0.081 seconds.
