1952 ca brakes
Alan vincioni View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alan vincioni Quote  Post ReplyReply Direct Link To This Post Topic: 1952 ca brakes
    Posted: 07 Jan 2021 at 2:35pm
I just installed new brake shoes with the axle removed. The shoes do not seem to conform to the drum until they are tight to the drum. I assume they just need to be run in but bind even when loose. Any suggestions would be helpful   Thank you
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jan 2021 at 6:21pm
 Whenever I put brakes in a B,C or CA I always use an old drum outside of the tractor to bend them to match the radius of the drum first.  I also always put the brakes in after all the other axle parts are in place.
