Kenworth Clutch |
Post Reply ![]() |
Johnwilson_osf ![]() Orange Level ![]() Joined: 29 Jul 2012 Location: Mount Bethel PA Points: 941 |
![]() ![]() ![]() ![]() ![]() Posted: 04 Jan 2021 at 5:03pm |
Happy New Year fellow Allis enthusiasts,
Here is the Answer to this question: I need a new clutch. Here is the question: My clutch pedal is engaging at the top of the stroke. I want to adjust the clutch, so I take off the access plate to try and move the adjustment bolt (it is the easy adjust style where you push in the bolt, and then turn). I cannot turn the nut. So either the mechanism is gummed up with clutch dust, or I am out of adjustment. The clutch chatters a bit every now and then, and slips occasionally. Before I get it torn apart, and replace the clutch, I would like to know the following: If I open the other access plate, and see the rest of the clutch, can I determine how much clutch is there. For example, If I had a brand new clutch in there, would I be able to see the thickness of the pads? When I search the web for pictures of a clutch, I can't find any picture that answers this. Anyone able to add some insight to this? Thank you, John
Allis Express: Eastern PA on Rt 80
8050, 8010, 6080, 190, D14, DA 6035, AA 6690, 5650, Gleaner F2 |
DMiller ![]() Orange Level Access ![]() Joined: 14 Sep 2009 Location: Hermann, Mo Points: 34144 |
Large Diesel Clutches have to be Pedal Applied to turn the adjusting ring, is the pedal blocked in the Down Position?
DMiller,
We had the clutch pedal pushed down when turning the adjusting ring. It would not spin. All I was doing was turning the entire pressure plate assembly.
Will have to pull clutch. Nothing else will work.
PaulB ![]() Orange Level ![]() Joined: 12 Sep 2009 Location: Rocky Ridge Md Points: 5142 |
Don't get the easy adjust as a replacement. The old type is tried and proven to work. Same goes for the Auto-Adjust ones. They will not work for the life of the clutch.
I have seen some that unbolt the easy adjust and go inside and pry them into adjustment.
Red Bank ![]() Orange Level Access ![]() Joined: 18 Apr 2018 Location: Germanton NC Points: 1051 |
Make sure it’s pushed in all the way, make sure the clutch pedal is pushed down all the way, and try to turn it counter clockwise and then clockwise to see if it will break loose.
Post Reply ![]() |
