Hd6g loader valve needed
dadsdozerhd5b View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dadsdozerhd5b Quote  Post ReplyReply Direct Link To This Post Topic: Hd6g loader valve needed
    Posted: 03 Jan 2021 at 1:57pm
Anyone have or know where a loader control valve for a hd6g? Older serial number as it has a Buda engine. Thanks
gemdozer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote gemdozer Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jan 2021 at 2:46pm
I should have some parts for control valve HD6
Post Options Post Options   Thanks (0) Thanks(0)   Quote dadsdozerhd5b Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jan 2021 at 7:36pm
Hector, do you have the whole valve? I would also be interested in just the relief valve section of the valve. I am working on one that has low hydraulic pressure and want to chance the valve and spring to see if performance improves before replacing the pump. If so, how much? Thanks
