one for the juicetricians,,,,,
desertjoe View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote desertjoe Quote  Post ReplyReply Direct Link To This Post Topic: one for the juicetricians,,,,,
    Posted: 02 Jan 2021 at 9:04pm
  OK, I gots another one for all the juicetricians on here,,,,
 On My Diehard 12 VDC battery charger the 3 position sliding switch that changes from 3 volt to 10 volt to 13 jump start is having trouble changing from one to other and must have some corrosion in the contacts as most of the time won't charge unless you jiggle the switch. It is a 3 position with 8 pins but only 5 of the pins have a wire hooked to it,,,?? I was able to get the PN from Sears Parts Direct as PN  0499000032 but you guessed it,,,, NLA !! There gotta be millions of switches on internet,,so what do I look for??  Most ads ask for "Pole and Throw" ,,? All I know is the switch is ON-ON-ON and most are ON-OFF-ON.
john(MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote john(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jan 2021 at 9:39pm
Is it a slide switch or a toggle switch?  You might take it apart and spray it with some brake cleaner, if ain't a sealed unit.
Dirt Farmer View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dirt Farmer Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jan 2021 at 11:36pm
Try entering your part number in Google along with the word "switch". You should get several listings but Sears and the other sites only show 3 pins on the switch. Good luck
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jan 2021 at 11:38pm
every time i have attempted to fix a battery charger...i end up just going and buying another!
klinemar View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote klinemar Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jan 2021 at 5:45pm
Many problems I have fixed with a 12 pound BFH tool and a powerful swing. And as Shameless said go buy a new one!https://youtu.be/SYqAnoBQyNM
Edited by klinemar - 03 Jan 2021 at 5:48pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jan 2021 at 6:52pm
you dont need to take the switch apart.. It will have crimped edges and have a couple small cracks around the side... or on each side of the slide... SOAK IT with  brake cleaner or WD40... then blow out with air.. do it again........ works about 80% of the time.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jan 2021 at 7:02pm
Joe... they gave you the wrong part number... Your number is a ON- ON switch with 3 pins and 2 positions...
Edited by steve(ill) - 03 Jan 2021 at 7:03pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jan 2021 at 7:06pm
Edited by steve(ill) - 03 Jan 2021 at 7:12pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote desertjoe Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jan 2021 at 7:22pm
 JEEEEZE,,kline,,you must be having a terrible bad hair day!! I'm sure GLAD there are good people like Steve and Dirt Farmer and John that are willing to help a member in need of some info he doesn't have. I honestly thought that was the main focus of the group.
Post Options Post Options   Thanks (0) Thanks(0)   Quote desertjoe Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jan 2021 at 8:22pm
 Aw heck,,Steve,,I had the switch apart,,(gently),,,before I read your last post and the stationary contacts on one side were worn pretty good is why it would only make contact if you jiggled the switch.
 Many THANKS for the link to ACRC Tools,,,I checked them out and found an exact switch  for only $12 bucks,,,,AND they also carry an amperes meter that is same as mine that I may order too,,!!  Many Thanks Steve,,,,ClapClap
Post Options Post Options   Thanks (0) Thanks(0)   Quote klinemar Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jan 2021 at 8:34pm
Joe, Shameless and I are willing to help anytime!
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jan 2021 at 9:00pm
Schumacker makes a LOT OF BATTERY chargers... If you get one at Sears, Menards, NAPA... chances are it is a Schumacker with different paint and decals !!
Post Options Post Options   Thanks (0) Thanks(0)   Quote desertjoe Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jan 2021 at 5:31am
 That right there is so true, Steve. Mine is a Sears Diehard that I've had for a good many years and still works many wonderfulls,,except it got where you couldn't tell which charging rate it was on. Ten Four on that site having what you need as far as battery Chargers. They have every part I would need to make mine brand new again,,altho some of the bigger parts are kinda pricy, but then again,,,them chargers these days have gotten so friggin expensive,,,!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote john(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jan 2021 at 8:26am
I had an old charger, probably 40 - 50 years old. It was the smaller size with the handle on top.  It musta weighed close to 40 pounds.  The case was made of a lot heavier steel then they are made out of now.  When I opened it up the diode pack was fried.  I figured it was time for the scrap pile.  I took down the info and looked online.  The company still exists and they still sell the same charger.  I guess they have a following.  They sent me the parts and now it has a new life.
Post Options Post Options   Thanks (0) Thanks(0)   Quote desertjoe Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jan 2021 at 9:59am
 Chit,,John,,,and here I was gonna send you a $20 and my address for that OLD wore out charger,,,,,,,,LOL
 That one sounds like what I'm workin on,,,,
 HMMmmmm,,,I'm bettin ole Shameless gots one I might buy for "parts",,ya know as a spare,,,,Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jan 2021 at 3:06am
I keep buyin em at auctions,,,,,,must have 20 of em layin around.  Still have my OLD Schumacher that I've also replace the switch on.  They just don't make em like they used to though.
We should meet up and go to Shameless' place and see what kind of stuff he's got hidden in all them sheds hes got.  Every time somebody asks for sumthin, he's got one.....
Post Options Post Options   Thanks (0) Thanks(0)   Quote desertjoe Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jan 2021 at 8:30am
 Hey Ted,,,now,,,don't go thinkin of me like one of them "sooners" ,,,,,but,,,,but,,,I done placed MY wishes to ole Shameless,,,,I'm just sittin here waiting on his approval so's I can hit the road,,,,,,,WinkClap
JoeO(CMO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeO(CMO) Quote  Post ReplyReply Direct Link To This Post Posted: 18 Apr 2022 at 9:06am
I'm gonna sorta jump in here.  I did take pics on my phone, now just to get them on a count of three to come onto this site.
Dakota Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dakota Dave Quote  Post ReplyReply Direct Link To This Post Posted: 18 Apr 2022 at 11:17am
my old one had a 4 position rotary switch. the switch fell apart. i just put a two position switch in its place taped off the 6V and boost leads only used the trickle and 10 amp postions.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 18 Apr 2022 at 11:45am
dj, checkyour OTHER 'thread'... FOUND what you need..info there....
here's the info....
The charger switch works as follows
1st position, 1--2 , 5--6 are connected
2nd position, 2--3 , 6--7 are connected
3rd position, 3--4 , 7--8 are connected
the Z strip ALWAYS has 2 connected to 7
clear as mud, right ?
You really need a DP3P slide switch.... Double pole, 3 positions.
One possible source...
dang only $3 CDN ! Digikey is GREAT....dealt with them of decades. Se what shipping costs are, minimum order and buy enough of them to make it worthwhile. if you need to buy 7, go for it....only $20.
OK I ghosted you, they're $2.22 each, shipping $5 USPS, $7 Fedex.....
man that's CHEAP !!! I'd still buy 5 of them.....no probably 10...
cheers
Jay
Edited by jaybmiller - 18 Apr 2022 at 11:46am
This page was generated in 0.316 seconds.
