High Tension Tower ?? |
FREEDGUY
Joined: 15 Apr 2017 Location: South West Mich Points: 5396 |
Topic: High Tension Tower ??Posted: 02 Jan 2021 at 5:27pm |
In the past 2 years, the local electric power company(AEP) has been replacing the 4 legged-spider looking towers with a single pole tower. These things are at a minimum 80 feet tall on a tapered post. How do they get such an animal "plumb" straight up
steve(ill)
Joined: 11 Sep 2009 Location: illinois Points: 90846 |
Posted: 02 Jan 2021 at 6:06pm |
the steel base is a flange on LARGER poles.. sets on 20 -40 studs with nuts on top and bottom ( buried in the concrete hole).. Adjust the nuts up and down to get flange level. The concrete base in the ground is probably 15- 20 ft deep for BIG pole... depending on the type of dirt. ............. smaller steel poles can be put in the ground just like wood.
Edited by steve(ill) - 02 Jan 2021 at 6:17pm |
FREEDGUY
Posted: 02 Jan 2021 at 6:32pm |
Thanks Steve, I understand the multiple "anchor bolts" protruding out of the MASSIVE concrete foundation, but just leveling the mounting plate ensures a "plumb" tower ??
TMiller/NC
Joined: 11 Sep 2009 Location: Lenoir, NC Points: 1776 |
Posted: 02 Jan 2021 at 6:44pm |
FreedGuy, don't know about power poles, but when the light house was moved they hung a plumb bob from top center hanging down to a circle on floor, plumb bob was maintained within the circle by adjusting jacks as light house moved. Possible to use one on inside of metal pole. Around here with wooden poles have seen the linemen use a string with a nut tied on one end, hold it out a arms length and sight pole.
SteveM C/IL
Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8984 |
Posted: 02 Jan 2021 at 11:09pm |
The rebar cage they put in the concrete is MASSIVE in both amount of steel as well as dia of bars.
shameless dude
Posted: 02 Jan 2021 at 11:35pm |
the transmission lines around here are 3 different types, the single steel pole set in concrete, the spider web 4 legged type set/bolted to leaning pillars of concrete and bolted down, and the 2 creosoted wood pole types set in the ground with crushed rock surrounding them in the holes.
DMiller
Joined: 14 Sep 2009 Location: Hermann, Mo Points: 35692 |
Posted: 03 Jan 2021 at 5:06am |
When I worked in the garage at UE we saw every version tower post and column. Saw lattice work towers on two legs with guide wires to anchors to four massive concrete piles with bolting cages set to extreme depth. Most wooden poles were set as noted by eye two or three crew with plumb sets at vantage points to ‘align’ the poles. Most steel column poles had a leveling head in base of column essentially a plate base with a welded beam pipe or bar set square the installers would set then the rest of the column survived from that. Corner sets were intentionally Leaned a few degrees away from the Pull of cable weight.
truckerfarmer
Joined: 26 Jan 2013 Location: Watertown, SD Points: 3312 |
Posted: 03 Jan 2021 at 8:00am |
Starting to see the laminated wood posts around here for secondary transmission lines.
'53 WD, '53 WD45, WD snap coupler field cultivator, #53 plow,'53 HD5B dozer Duct tape.... Can't fix stupidity. But will muffle the sound of it! |
DMiller
Posted: 03 Jan 2021 at 9:15am |
Tried those around here several years ago, do not see all that many as rot would start at the Glue Joints where water intrusion could gain access. Great for drier climates.
steve(ill)
Posted: 03 Jan 2021 at 9:58am |
FREEDGUY
Posted: 03 Jan 2021 at 6:49pm |
YEP, that's what has been going in the ground "here"
!! Thanks for that picture Steve ![]() !! |
shameless dude
Posted: 03 Jan 2021 at 10:05pm |
looks like a base mount for one of them wind turbines.
JohnColo
Joined: 03 Apr 2020 Location: Niwot, CO Points: 1263 |
Posted: 03 Jan 2021 at 10:29pm |
Except smaller.
