Wheel Painting |
Post Reply ![]() |
GSTROM99 ![]() Silver Level ![]() ![]() Joined: 12 Dec 2020 Location: Greene, IA Points: 246 |
![]() ![]() ![]() ![]() ![]() Posted: 01 Jan 2021 at 3:39pm |
When repainting the front wheels, what is the preferred/easier order? Paint the cream, then mask off and paint the silver? Or paint the silver, then mask off and paint the cream?
DSeries4 ![]() Orange Level ![]() ![]() Joined: 12 Sep 2009 Location: Ontario, Canada Points: 7505 |
I don't think there is an easy or preferred way. I told my painter how they should look and let him do it. He did say it took a lot of time. The question is: Do you want it done fast or do you want it done good? I had these done last winter. ![]() |
AC720Man ![]() Orange Level ![]() ![]() Joined: 10 Oct 2016 Location: Shenandoah, Va Points: 5232 |
What series and years were they painted that way?
john(MI) ![]() Orange Level ![]() ![]() Joined: 12 Sep 2009 Location: SE MI Points: 9262 |
Paint them all cream or all orange.
SteveM C/IL ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8628 |
Not familiar with that scheme myself.
jaybmiller ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Location: Greensville,Ont Points: 24694 |
gee, I'd love to know HOW the factory did it ! All I see is a LOT of tape and time needed to properly mask them and I can't see any mfr doing that unless they had some 'tricks' up their sleeves.I'm thinking shoot the centers,wait a day,mask the centers, shoot the rest, wait, then remove tape.... still seems like a LOT of $$$ work for rims though.... be interesting to know how DS4's were done.
Mine is a Series 3 D17. Here's what my Grandpa's D15 looked like when new. I'm going with this style. ![]() |
ac160 ![]() Silver Level ![]() Joined: 02 Dec 2010 Points: 408 |
I found painting the outside(silver) first and then the cream on the center second. I used a lot of newspaper and some tape to wrap everything up that I didn't want painted.
Sugarmaker ![]() Orange Level ![]() ![]() Joined: 12 Jul 2013 Location: Albion PA Points: 8521 |
I guess I have done it both ways. But the last ones I did I used some different aluminum and sprayed it first. I had over spray on the centers. Well the cream did not like the silver. Took a month to dry. So try to get paint that is compatable is my point. Same brand primer and top coats. I have used rustoleum spray cans for most of mine.
I Think your tractor is going to look awesome with those! I tend to go with more of a cream than a stark white. Just happens to be what I like. some pics: ![]() ![]() ![]() ![]() ![]() These are from my rear of the WZ pulling tractor. Regards, Chris
Ted J ![]() Orange Level ![]() ![]() Joined: 05 Jul 2010 Location: La Crosse, WI Points: 18943 |
Has anybody tried to do the centers first and then put a piece of cardboard over the center and spray the silver? Or do you think too much over spray will get on the cream centers?
I am sure a well designed mask would work pretty well. I am always to lazy to build the mask.
Regards, Chris
You would still get overspray, and you would not get silver in the slots between the rim and center. If I recall, my painter did cream first, then taped and covered mysteriously - said he ended up using a deck of cards somehow. I didn't see how he did it, but I am happy with the end result.
Well, I painted the silver first, then the cream. I used rattle can Rustoleum - Aluminum for silver and Almond for cream. Came out pretty good. Good masking is crucial. ![]() |
mdm1 ![]() Orange Level ![]() ![]() Joined: 12 Sep 2009 Location: Onalaska, WI Points: 2678 |
DSeries4 I would guess he slid the cards under centers where they attach to the rim. Maskings not that hard just time consuming. I always hated when someone paints the rims and gets over spray on the tires!
Bob-Maine ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: Central Maine Points: 922 |
MDM 1. Someone posted on here a while ago that a solution to keeping overspray off the tires is this. Cut a circle, just smaller than the outside diameter of a rim bead, in a piece of cardboard. Then deflate the mounted tire and cut the cardboard from the outside to a point on the circle. Slide the cardboard between the tire and rim all the way around. Then paint. It keeps the paint off the tire and eliminates the damage to the paint if you mount the tire after the rim is painted. I used this on the D-14 I am restoring and it worked great. Bob@allisdowneast
I used to think I was indecisive, but now I'm not sure.
Sounds like a great idea!
GSTROM99,
The front rims look awesome! You did a good job! Were they sandblasted? I like that paint scheme. But that's just me! Regards, Chris
plummerscarin ![]() Orange Level Access ![]() Joined: 22 Jun 2015 Location: ia Points: 3922 |
![]() ![]() Dismount tire and blasted. POR15 inside rim then mount tire when dried. Do not inflate tire yet. 4 mil plastic cut smaller than rim diameter for a snug fit. I would think painting center first then masking for rim would be easier. I'll let you know when I get that far. Edited by plummerscarin - 03 Jan 2021 at 6:39pm |
Thanks! The front tires were bad, that's why I pulled 'em all apart. New Carlisles are 'en route. They were not sandblasted. I just ground the rust off the inside, sanded smooth with 120 grit, masked, primed and painted. If the tires weren't so bad, I wouldn't have done this, but I'm glad I did. I'm not doing a restoration, since it runs good and I think this was a good "barn find". I had to weld up a rusted hole, which I found when I got them cleaned up... I'm going to have to be careful, when I mount the new tires. Edited by GSTROM99 - 04 Jan 2021 at 8:41pm |
I had painted some Cub wheels and mounted tires afterward. Even with plastic guards on the irons the paint got chipped. That is why I mounted the tires first before final paint on those 7060 wheels. Inflate the tires after the paint dries. No chips, no overspray
Plummerscarin, I like your idea too. Bob@allisdowneast
JayIN ![]() Orange Level ![]() ![]() Joined: 18 Dec 2009 Location: SE/IN Points: 1982 |
I sprayed the cream centers first and then hand painted the Kentucky chrome next.
Dave in il ![]() Orange Level ![]() ![]() Joined: 22 Sep 2009 Location: Manville Il Points: 1748 |
Originally, would the rims have been galvanized and the the painted center riveted in?
AGCO My Allis Gleaner Company
mruhlig77 ![]() Orange Level ![]() Joined: 19 Aug 2014 Location: central Indiana Points: 592 |
Careful masking helps...I have painted lots of wheels by mounting them on a spindle or axle and turning them as I paint...a steady hand stops overspray....done it on spin outs...spin all the way out , paint, spin all the way in..paint.....Mark
Post Reply ![]() |
