Hydraulic oil
rlee View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rlee Quote  Post ReplyReply Direct Link To This Post Topic: Hydraulic oil
    Posted: 01 Jan 2021 at 12:20am
I see there is a big difference in the price of hydraulic oil that replaces AC 821 power fluid. From $387 to $976 for a 55 gal drum(on line price). Is it worth the price difference to by the expensive fluid? Any suggestions in this area?      Thank you
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jan 2021 at 2:25am
i bought my last drum of hyd fluid from Sams Club, it was the cheapest, but was quality oil. i think it was Shell oil. price was under $400.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jan 2021 at 5:57am
gee, all I'm thinking is you either have a LOT of orange or one with a BIG leak !!
I buy my 5G pails at Wallyworld.......the owner of Sams BTW.
Stan R View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stan R Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jan 2021 at 6:39am
Are the oil specifications the same? If so, then go with the cheap. If not, do some more investigation on it. And follow the oil specs of the owners manual's recommended oil.
In the early 90's, I worked on a design team to expand some lube oil blending plants for Chevron. We had their recipes as they needed to be put into the computer programs, and most oils in the same family (ie 10w-40) are very similar except for a few "unique" additives.
Their oils were made and branded for 100's of different sellers.
Edited by Stan R - 01 Jan 2021 at 7:02am
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jan 2021 at 7:28am
Just plain 303 is junk and won't work properly in extreme cold or hot conditions, I get the Pureflo in a 5 gallon yellow bucket it's good for new stuff clutch packs and brakes, so it should be good in One Hundred series AC,s, , in this case - cheap really isn't good
rlee View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rlee Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jan 2021 at 7:38am
Thanks everyone for your input. I am going to change hydraulic oil in several tractors this winter, thats why so much is needed. I want to make the right choice on brands of oil.
Jim.ME View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim.ME Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jan 2021 at 7:57am
The oil/fluid you are looking at should clearly state, either on the container or a technical data sheet, it meets the Powerfluid 821 XL spec (or at least Powerfluid 821 which was the previous spec).  If they don't show the manufacturer specs the oil/fluid meets, I would avoid it.
GSTROM99 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GSTROM99 Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jan 2021 at 10:18am
I use NAPA Premium Tractor hydraulic fluid, but in 5 gallon pails, but a 55 gallon drum is $560...
NEVER green View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote NEVER green Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jan 2021 at 10:41am
   Cenex Qwiklift is the best, actually has GL-4 gear oil protection qualities.
Clay View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Clay Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jan 2021 at 11:39am
I only use John Deere Hy-Guard hydraulic oil in my equipment.
It may be a little expensive but the peace of mind knowing I have a quality oil is worth the extra cost.
Spending a little more now is much more economical than spending a fortune on repairs.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jan 2021 at 12:36pm
Allis, FORD, GM, CAT, and JD all do NOT make oil... There are several manufacturers in the USA and they make ALL the oil for EVERYONE... They try to STANDARDIZE on some blend and addatives to meet several specs.... That is why you should look at the SPEC on  LABEL... It will say something like  " MEETS Allis 821, CAT TO2, CASE Hy-Trans...... etc "
A good quality oil ( not necessarily expensive ) will meet 10- 20 different Vendor Specs.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jan 2021 at 12:38pm
One way is to look at the spec numbers , Military Spec # matching is a good way to find if it will meet the requirements .
 Was using a so called SAE rated oil from a large farm store - ended up having rust form on dip stick of engine - it seems the ability to disperse oil and not hold it suspended was not in blend . changed brands and problem went away .
 Friend worked at local oil blending plant - all stock came in in rail tankers as #10 weight base stock - then processed into final product . I got 50 gallons of IH High Tran from him but said IF I wanted the true IH blend I had to wait a few weeks till they batched it but could get another labeled product that was slightly different blend but was said to meet the specs but different Military grade number . Said I would wait .
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jan 2021 at 12:45pm
Here is one example of CENTEX brand.........
randy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote randy Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jan 2021 at 12:52pm
I use Cen-Pe-Co hyd oil in my 8050, 8070, and 7060. I use the cheaper oil in my older tractors. I used to use the cheaper oil in all of them. My 8050 is used on my sprayer with a hyp pump.
It seems to run smoother and quieter with the Cen-pe-co hyd oil, just my thoughts. Older tractors dont really need the newer oil with all the extra additvies.
Randy
BrianC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BrianC Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jan 2021 at 12:54pm
I would like to mention that Chevron (Delo brand) sponsors the FFA
tractor restoration competition. So maybe that will help you with deciding
where to spend your money. If price and quality is similar, why not go with the brand that helps get the kids rebuilding tractors?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jan 2021 at 1:00pm
All good info - one thing i would pay special attention too is how the condition the old oil is in- as in milky looking, water in it, if so flushing with diesel fuel may be needed
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jan 2021 at 1:05pm
for example SUNOCO $400. ...
Edited by steve(ill) - 01 Jan 2021 at 1:09pm
Adam Stratton View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Adam Stratton Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jan 2021 at 8:37pm
We get ours from Wallace Lubricants. Dont know if you have any where you are. Dont remember the exact drum price but less than any shared so far. Meets 821 spec. Their house brand is Pinnacle, but weve had more than one drum of their Pinnacle oil show up with the Mobil pegasus on the bung cover.
