What Fails On An Intank Fuel Pump ?
FREEDGUY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Topic: What Fails On An Intank Fuel Pump ?
    Posted: 30 Dec 2020 at 5:22pm
Is it electrical connections ? Motor fail ? Impeller ( not sure how the pumps function Embarrassed) fail or something else ?? Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 30 Dec 2020 at 5:46pm
if your talking about a car/ truck... It is the bushings on the end of the motor.. Bushing wears a little and rotor runs off center. When you stop, the rotor is laying aginst the windings ( no air gap) and will not start back up.... That is why if you SLAM the door or BUMP the truck, it will sometimes take off and run for a while... temporary fix.
Dakota Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dakota Dave Quote  Post ReplyReply Direct Link To This Post Posted: 30 Dec 2020 at 8:39pm
The motor that is cooled by the gasoline bearings get loose. The shaft runs a little off and the armature sticks to the field magnets. If you get a car that's been run low on fuel the fuel pumps go out on a regular basis. If your going to change one out get the module instead of just the pump. Changing the pump only is a little Cheeper but you'll be doing it again soon.
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Posted: 31 Dec 2020 at 7:07pm
Yes, I was asking about a "gas engine/fuel injected engine of NO brand in particular Wink. DD, you speak of a "shaft" (so did Steve), but what does the shaft "drive" ?? is it an impeller like a water pump or a different mechanism ?? Thanks to both of your replies and have a safe and happy New Year Thumbs Up !!
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 31 Dec 2020 at 8:37pm
shaft / rotor = same thing... Just a vertical motor with a little pump/ check valve on the end of it.. bushing on each end of the motor... .. lubed and cooled by gasoline as Dave said.... the bushings / brushes ,  wear due to heat and runs off center.
Edited by steve(ill) - 31 Dec 2020 at 9:04pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 31 Dec 2020 at 11:07pm
i had a conversion van that the pipe inside the tank broke off away from the pump, pump still pumped, but it wasn't going into the tube that carries it to the engine. was a simple fix by the dealer, think it cost me around $60. to have fixed.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jan 2021 at 7:42am
Still wonder about electric motor in gasoline- but it's trued and true!
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jan 2021 at 10:26am
So long as liquid in the pump no BOOOM!!!  Vapors are what burn or explode.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jan 2021 at 10:32am
You can toss lit matches into a pail FULL of gasoline all day long.....
just don't do that when 1/2 full !!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jan 2021 at 6:01pm
Now wait a minute, half or full, those buckets (pails) are putting off vapors Big smileBig smile !!
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jan 2021 at 8:12am
i've also throwed lit matches into gasoline and had them go out. was winter time tho.
Tbone95 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jan 2021 at 8:16am
I wouldn’t trust it on a dead calm day. Could very easily get a flash of the vapors over the bucket. It all makes sense, but conditions make the difference.
tadams(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tadams(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jan 2021 at 12:27pm
  Especially with this great gas we have now, it'll probably put the match out, no fumes
This page was generated in 0.277 seconds.
