7040 Dual Wheel pulling
Smokey Joe View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Smokey Joe Quote  Post ReplyReply Direct Link To This Post Topic: 7040 Dual Wheel pulling
    Posted: 04 Sep 2010 at 6:17pm
3- 6030's, 2-4640's,1-7040AC
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 04 Sep 2010 at 7:15pm
WOW thats pretty !!! What class, and howd you do ? Looks like you got a little fuel turned to her , thats how they run best !!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Smokey Joe Quote  Post ReplyReply Direct Link To This Post Posted: 04 Sep 2010 at 7:33pm
Got 5th out of 6th that was the 25,000 lb class if you see my other post you'll see powershift slipping was pulling 4th gear no problem and she stalled. Beat one 4640 and still was within 3ft of a 6030. I was still proud i was weighing about 21,000 no fluid in tires.
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 04 Sep 2010 at 9:00pm
looks like a 7080 muffler. I'm guessing there has been some work done to that 7040! nice! You will overpower the torque limiter if you crank the fuel up past 200hp.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Smokey Joe Quote  Post ReplyReply Direct Link To This Post Posted: 05 Sep 2010 at 6:02am
Tractor has 7080 injectors and muffler fuel pump maxxed out with holley blue electric pump feeding fuel from tank, Dynoed 180hp before the injectors and electric pump!
