How to add pictures
Smokey Joe View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Smokey Joe Quote  Post ReplyReply Direct Link To This Post Topic: How to add pictures
    Posted: 04 Sep 2010 at 4:15pm
How to post pictures on sight?
Jeff Z. NY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jeff  Z.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 04 Sep 2010 at 4:51pm
Sent you a PM.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 04 Sep 2010 at 5:21pm
Coljus
Posting Pictures
To post a picture from your computer, first click on  new topic + or post reply/ . Do not use the quick reply box at the bottom of a previously posted topic. At the top of the box that opens is a row of icons. In the middle of that row is a picture of a tree, click on it. A window that says image properties will open, if that window is small, maximize it so you can see everything in the window. Click browse and find the picture on your computer and open it. Click upload and a small window will open asking you to be patient, click OK in the small window. The picture will appear in the box on the lower right side. Check the width and height of the picture. If the numbers are greater than 800 wide and 600 high, the picture will not be seen completely on the forum. You can change these numbers but need to keep the ratio the same between them or the picture will be stretched. Click OK at the bottom and the picture will appear in your post. You can add text to the post before or after uploading the picture. It is easier to insert your text first. Now click post reply or post new topic and you are done.
Faith isn't a jump in the dark. It is a walk in the light. Faith is not guessing; it is knowing something.
"Challenges are what make life interesting; overcoming them is what makes life meaningful."
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 04 Sep 2010 at 7:30pm
Coke, I think I have those exact words in a word document I saved a while back. LOL Charlie
Post Options Post Options   Thanks (0) Thanks(0)   Quote Smokey Joe Quote  Post ReplyReply Direct Link To This Post Posted: 04 Sep 2010 at 7:39pm
Thank You everyone i have it now. I'll post some more orange photos.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 04 Sep 2010 at 10:32pm
Did a search on posting pictures and yours was the first post to come up..
DanNESD View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DanNESD Quote  Post ReplyReply Direct Link To This Post Posted: 04 Sep 2010 at 10:33pm
The picture I wanted to download was to large (to many KB).  Is there any way to shink the KB?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Smokey Joe Quote  Post ReplyReply Direct Link To This Post Posted: 05 Sep 2010 at 6:05am
You have to go to edit picture choose a custom size 600x800 is the max it can be and save it that way and attach.
