WTB Allis Chalmers B Thermostat Housing
MDWilliams338 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MDWilliams338 Quote  Post ReplyReply Direct Link To This Post Topic: WTB Allis Chalmers B Thermostat Housing
    Posted: 21 Dec 2020 at 2:53pm
Anybody got a good one of these for sale?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 21 Dec 2020 at 4:30pm
What's the part number
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 21 Dec 2020 at 4:39pm
Michael, i think the C, CA, D10, D12, etc all used that  housing... slight variation in the D series, but it will work...... if you find someone with any one of them.
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 22 Dec 2020 at 7:26am
That thermostat housing was only used on the Later Bs and later CAs, 2 piece bypass type. The smaller D series engines used a single piece housing that the other half was casted into the front of the head.  If you can't find the 2 piece (aluminum type) the Cast iron type (non bypass) with the bottom steel plate, that was used on most all B,C & CA tractors will interchange.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MDWilliams338 Quote  Post ReplyReply Direct Link To This Post Posted: 22 Dec 2020 at 8:39pm
Mike....I’m not sure.My Dad put it back on before I could look at it,if it even had one on it.
Steve and Paul... appreciate the info and I’ll see if I can’t run one down somewhere.I’m looking for another because I’m not confident this one isn’t going to leak.
This page was generated in 0.151 seconds.
