1952 allis CA
Alan vincioni View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alan vincioni Quote  Post ReplyReply Direct Link To This Post Topic: 1952 allis CA
    Posted: 18 Dec 2020 at 12:49pm
Hello. First time in. I have a final drive clutch that is slipping when under a load. The pto is fine but drive slips. It appears to have good disk. It drives fine until a load is applied. Any help will be great. Thank you
tadams(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tadams(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 18 Dec 2020 at 2:01pm
Are you sure the hand clutch isn't slipping?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 18 Dec 2020 at 3:25pm
Alan,
Welcome! We will require some pictures of this tractor too!Smile Just sayin.......!
Dakota Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dakota Dave Quote  Post ReplyReply Direct Link To This Post Posted: 18 Dec 2020 at 4:09pm
The final drive clutch is the hand clutch. You can try the adjustment pretty much never works. When you rebuild it you have to grind a few thousandths off the housing support towers. I don't rember off the top of my head but someone did a nice write up on rebuilding the hand clutch. I think it's in the repair forum.
ac hunter View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac hunter Quote  Post ReplyReply Direct Link To This Post Posted: 18 Dec 2020 at 5:02pm
Send it to Rick. He is on this forum and does a great job. Had him rebuild my CA hand clutch a couple of years ago. He will walk you through any problems too.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alan vincioni Quote  Post ReplyReply Direct Link To This Post Posted: 18 Dec 2020 at 5:08pm
Hello. I believe it is the hand clutch. I took it apart and cleaned the disk. It did have grease and a lot of debris in the housing as well as brakes that are completely worn plenty of disk left on clutch. I was curious about the springs applying enough pressure. milling down the housing would help. Not sure how to test without putting it back together
By the way. If I can figure out how I will send photos of both sister tractors I have restored. Thank you
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alan vincioni Quote  Post ReplyReply Direct Link To This Post Posted: 18 Dec 2020 at 5:11pm
You are the second person who has mentioned Rick from Missouri. Have not been able to get his info. He is infamous. Thank you
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 18 Dec 2020 at 8:08pm
Gary(MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 18 Dec 2020 at 9:36pm
Rick is the man to go to with clutch problems. I have had him build 2 pulling clutches and a hand clutch and pressure plate. All worked perfect. Thanks for Rick. Have a great day and MERRY CHRISTMAS to all. Gary
Bill Long View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill Long Quote  Post ReplyReply Direct Link To This Post Posted: 18 Dec 2020 at 9:49pm
Be certain to grind 1/8" off the "ears" of the clutch housing.  We found out back in the 50's with some experimenting.   Worked fine   Also, we replaced all the springs balls and clutch pads.  Worked fine thereafter.
There is also a good post on the CA hand clutch in the Knowledge section of this forum
Let us know how it goes.
Welcome!  You have a great plowing tractor.  Really powerful for it's size.
Would love to see pictures.
Good Luck!
Merry Christmas!  Happy New Year!
Bill Long
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alan vincioni Quote  Post ReplyReply Direct Link To This Post Posted: 18 Dec 2020 at 10:33pm
Thank you. Having trouble finding parts. One source wanted $100 for the springs.   I will try again to post photos of both CA they are great running tractors. And pull three furrows easily. Just been lucky to have both sisters same year make and model only a few serial numbers apart. Thank you for the help. Anxious to get her back working to get the field turned under
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 19 Dec 2020 at 8:13am
Hi Alan
Welcome to the Allis Forum. Lots of great info on here regarding Allis Chalmers.
You have another Forum Member near you in NM, goes by the name 'Desert Rat'.
No wait that's not right, it's 'Desert Joe' LOL
Here is the link for CA Axle Clutch Repair by GregLawlerMinn
Picture #3 describes removing metal.
https://photos.google.com/share/AF1QipNmvFVC1Hc3h0hiNz2BbJBRNy6f1Cmoz_diCBsIxEZMMvioKVnnqpFMzoIQRvzDsQ?key=cW9ra3hqWnFLU1ZBTWpiMWhMU0RyYld5ZTZvTDN3
Post Options Post Options   Thanks (0) Thanks(0)   Quote tadams(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 19 Dec 2020 at 2:10pm
My hand clutch loosens up I need to tear it apart and put some lock tight on the bolts that hold it together.
This page was generated in 0.135 seconds.
