7000 ps end cap
tnboss View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tnboss Quote  Post ReplyReply Direct Link To This Post Topic: 7000 ps end cap
    Posted: 14 Dec 2020 at 9:51am
Replacing the low range clutches in my 7000, Has wore grooves in the heavy end plate, can I polish the other side up and flip over afraid grooves will ruin new friction plates. Thanks for any help.
NEVER green View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote NEVER green Quote  Post ReplyReply Direct Link To This Post Posted: 14 Dec 2020 at 10:57am
   Dont see why not, I did on my 7040.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 14 Dec 2020 at 11:59am
I think I would grind the damaged side to smooth. I don't think the front face was ever finished off, was it ??
Hurst View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hurst Quote  Post ReplyReply Direct Link To This Post Posted: 18 Dec 2020 at 8:02pm
Check for flatness too. Mine was warped when I rebuilt mine. If you’re working on a black belly that uses it as an inching clutch, they take a beating. In all honesty, if I was doing it again and didn’t find a good low hour used clutch pack, I would get a quote from a local machine shop to make one. I don’t remember there being much complicated about them.
Hurst
1979 Allis Chalmers 7000
5800 Hours
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 18 Dec 2020 at 8:05pm
There may be room enough to make it 1/8" thicker, which would help with warpage over time. Machine it down at the O.D. to still use the same bolts, but thicker where the heat actually is.
