712 Shuttle, No Reverse
Albow44 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Albow44 Quote  Post ReplyReply Direct Link To This Post Topic: 712 Shuttle, No Reverse
    Posted: 13 Dec 2020 at 4:36pm
Just finished changing all the oil and belts on my Shuttle, everything seems to be good, except now it will not go in Reverse and it wants to move forward when in neutral. The brake band around the planetary pulley seems tight enough when I pull lever into the reverse position. Any help or adjustment advice would be more than welcome. I’m trying to get the plow ready for a snow storm this week.
Edited by Albow44 - 14 Dec 2020 at 3:12pm
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 13 Dec 2020 at 6:32pm
   The brake band seems tight enough when I pull lever.
That doesn't seem to make sense.
How could the tractor move if the Brake Band is tight?
Farther down in this link is a description on replacing the Belts.
https://simpletractors.com/forums/topic/24043-belt-replacement-on-a-shuttle/
Edited by Gary - 13 Dec 2020 at 6:42pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Albow44 Quote  Post ReplyReply Direct Link To This Post Posted: 13 Dec 2020 at 7:04pm
Sorry for the confusion. I’m referring to brake band on the transmission. Not the parking brake.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Albow44 Quote  Post ReplyReply Direct Link To This Post Posted: 16 Dec 2020 at 1:28pm
Solved: (I Hope) The brake band around the planetary pulley needed to be tightened/adjusted in neutral and in reverse. Seems to be moving ok now. I do think I'll need another forward drive pulley brake pad though as it still tends to creep forward when in neutral.
