Bevel Gear Box |
Albow44
Topic: Bevel Gear BoxPosted: 11 Dec 2020 at 5:21pm |
Hey all, I'm in the process of getting my 712 Shuttle ready for the winter plow season and I'd like to change the BGB Oil. The manual states to fill it up to the "end of the dip stick". How much Gear Oil is that approximately? I have a giant jug, and I don't want to pour out more than I have to and I'm not seeing an estimated amount anywhere online.
Thanks in advance. Alan
AC720Man
Joined: 10 Oct 2016 Location: Shenandoah, Va Points: 5453 |
Thanks(1)
Posted: 11 Dec 2020 at 10:29pm |
I don’t have a a manual on that tractor. Try a pint at a time, after 1 pint check it. If not on the dipstick add some more. Go a 1/2 pint at a time. Slow pour once it hits the dipstick until full. A little research will get you the proper info. Just guessing here when I am unsure.
Albow44
Posted: 12 Dec 2020 at 8:51am |
Thanks. I guess I'll try that. I haven't been able to find an exact amount anywhere.
jaybmiller
Joined: 12 Sep 2009 Location: Greensville,Ont Points: 25180 |
Posted: 12 Dec 2020 at 3:49pm |
hmm.. you could measure the BGB, figure out the volume, cut in 1/2 and guesstimate that _might_ be close to the volume ?? Say the BGB is 8x8x8 inches. that's about .3 cuft or 20 pints...,/2 ( volume of gears+shafts.... makes about 10 pint needed. |
Dakota Dave
Thanks(1)
Posted: 12 Dec 2020 at 5:31pm |
It's less than a quart I changed my simplicity used a quart bottle had quite a bit left. The rest filled my JD gear box.
Albow44
Posted: 12 Dec 2020 at 5:58pm |
@Dakota Dave, You are correct, I filled it today. Its about 3/4 of a quart.
Thanks All!
