axle
D19allisowner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote D19allisowner Quote  Post ReplyReply Direct Link To This Post Topic: axle
    Posted: 09 Dec 2020 at 11:01am
I know this might be a long shot but dose anyone ever seen one of these before. It might be from a Plymouth. It has left hand threads on one side and they are bolts and not studs.
If you choose not to decide you still have made a choice.
FloydKS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote FloydKS Quote  Post ReplyReply Direct Link To This Post Posted: 09 Dec 2020 at 12:00pm
had a homemade trailer with that set up... ?chrysler?  there should be some experts on here who know.
HD6GTOM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HD6GTOM Quote  Post ReplyReply Direct Link To This Post Posted: 09 Dec 2020 at 5:18pm
In the 22+ years I owned the tire shop, I can only remember Chrysler\Dodge/Plymouth using that concoction. Don't know about foreign stuff.
Boss Man View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Boss Man Quote  Post ReplyReply Direct Link To This Post Posted: 09 Dec 2020 at 6:32pm
Looks similar to my Desoto
HudCo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 09 Dec 2020 at 11:23pm
my plymouth horizon think it was a 88 was that way
john(MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote john(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 10 Dec 2020 at 8:49am
My 55 Willys I just sold was that way.  The Jeep is narrower than a car or truck, so you could narrow it down with that measurement.
Post Options Post Options   Thanks (0) Thanks(0)   Quote D19allisowner Quote  Post ReplyReply Direct Link To This Post Posted: 11 Dec 2020 at 12:15pm
I was thinking it was something from the thirties or forties  with the nut on the end of the axle like that.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 11 Dec 2020 at 12:22pm
With the drive hub being separate from the axle and a nut locking the two together it seems it would be in the 50's or before . Would say something in the Chrysler Corp family but what model would be a toss up - might measure the on center circle of lugs and then check what vehicles used that center dimension to find out more
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 11 Dec 2020 at 5:49pm
VW had that type too
JohnColo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JohnColo Quote  Post ReplyReply Direct Link To This Post Posted: 11 Dec 2020 at 8:01pm
VW never had axles like that' just short ones from the transaxle.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 11 Dec 2020 at 8:19pm
32 to 48 ford used a bolt on hub separate from axle , and up to 39 they used what was called a banjo hum with bolt patter out near the edge of brake drum . (similar to VW rim)
 But not many besides Chrysler corp used the left hand thread  let alone bolts
Thad in AR. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Thad in AR. Quote  Post ReplyReply Direct Link To This Post Posted: 12 Dec 2020 at 4:58am
It has a removable pumpkin like a Ford. It looks like an early 9” Ford
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 12 Dec 2020 at 6:08am
gee, I gotta ask 'why' ? Odds are good it's a 'dodge family' axle but you need to totally clean it up and get a casting number, compute gear ratio and bolt pattern to narrow down when it was built.seems like a LOT of work only to find out no one wants it and at 3c/# you've lost a lot of $ ,cleaning it up...
jes curious as to the 'purpose of the exercise'......
Jay
This page was generated in 0.052 seconds.
