HD11e fuel issue
Engineerken View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Engineerken Quote  Post ReplyReply Direct Link To This Post Topic: HD11e fuel issue
    Posted: 06 Dec 2020 at 8:19am
Hello
I have a 1964 HD 11e, and having fuel issues. It was running just fine, i am not my getting fuel to the first fuel filter from the tank, i removed the gas cut off valve, and gas comes out, but not like it should. Is there known issues in the tank that could cause this, besides build up?
What do I need to check
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 06 Dec 2020 at 10:18am
Will be short lengths of rubber fuel lines between tank and engine, need to open Downstream on each of those to verify has not blistered internally and shut off flow.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Engineerken Quote  Post ReplyReply Direct Link To This Post Posted: 06 Dec 2020 at 11:03am
I am not getting fuel from either one, the return or the main line, from the tank. I can blow air to the tank, and gas comes out, then the flow stops
Post Options Post Options   Thanks (0) Thanks(0)   Quote Engineerken Quote  Post ReplyReply Direct Link To This Post Posted: 06 Dec 2020 at 11:09am
I replaced the main fuel line, thought that may be an issue
