Oil Viscosity ?
FREEDGUY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Topic: Oil Viscosity ?
    Posted: 05 Dec 2020 at 6:36pm
Can a heavier weight oil be introduced into a 5.4 Ford engine with 180K+ miles that uses  2 qts. between oil changes ?  I'm currently using  5W20 conventional BTW. Thanks.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hubert (Ga)engine7 Quote  Post ReplyReply Direct Link To This Post Posted: 05 Dec 2020 at 10:04pm
With over 230K I am still using the Motorcraft 5w20 synthetic blend except when I messed up and bought a few quarts of 5w30 for top offs. I was losing around 2 quarts between changes but found it had a small leak at the pressure sending unit, now it uses about a quart on 5K change intervals. 99 F150 with 5.4. The 5wXX lubes better on startup than a thicker oil. Personally I would stay with the recommended oil.
Edited by Hubert (Ga)engine7 - 05 Dec 2020 at 10:06pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 05 Dec 2020 at 10:42pm
You could change to 5w30 and still have the low viscosity for winter use. If you wanted to use 10w30  next summer, that would not be a problem. .... your motor is a 2005 or 6 which has the VCT system... It has small oil ports for the controls.. It dont like "thicker" oils.
Hubert is right.. Look around the oil pan and valve cover areas for a small leak.. Normally they dont "burn" that much oil.
Edited by steve(ill) - 05 Dec 2020 at 10:43pm
tom51 View Drop Down
Bronze Level Access
Bronze Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote tom51 Quote  Post ReplyReply Direct Link To This Post Posted: 06 Dec 2020 at 12:08pm
Had a 97 F-150 with a 4.6 used a quart every 2500 miles was using 10w-40. Switched
to 15-40 at 175k reduced oil consumption considerably between oil changes (5000) miles dry engine no leakes sat outside no trouble starting in winter (live in wi.). Ran it like that till I got rid of it (over 300k miles).
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Posted: 06 Dec 2020 at 4:37pm
There are "weeps" of oil film on the underside of bell housing when I perform my 4000 mile oil change, but NO oil spots/drips under it ever Embarrassed . The conventional isn't horribly priced to keep topping off, synthetic $$ would make me think twice about what route to go in the near future though Wink . Thanks guys
Yes, this is an '05 model
Edited by FREEDGUY - 06 Dec 2020 at 4:38pm
Coke View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke Quote  Post ReplyReply Direct Link To This Post Posted: 06 Dec 2020 at 9:56pm
Is it safe to switch from conventional to synthetic on an old engine?
I was told switching to synthetic may soften up older hardened seals and cause more leaks?
Don't know if that is apocryphal or not.
1957 D17 Diesel w/ M&W Pistons
Tbone95 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 07 Dec 2020 at 7:22am
Synthetics flow very well, and maintain that flow spot on to their viscosity rating. Putting them in an older engine may also do some cleaning, in some ways cleaning that may be more than the old girl can handle (dissolving deposits that mask or slow down leaks and weeps). But aren't "hardened" seals more likely to leak than a soft one? Maybe in the end we're kind of saying the same thing.
Roger (NE) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Roger (NE) Quote  Post ReplyReply Direct Link To This Post Posted: 07 Dec 2020 at 7:35am
Might try Valvoline Max life in the same viscosity you're using now. Have had good luck with it reducing oil consumption in high mileage engines. Seems to have an additive that helps over time.
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Posted: 07 Dec 2020 at 6:05pm
Thanks Roger, I use Super Tek High Mileage oil already.
Ray54 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ray54 Quote  Post ReplyReply Direct Link To This Post Posted: 07 Dec 2020 at 8:24pm
There are some that think it is very important to not change brands, it never has bothered me. I try to buy what is on sale, not that much has been on sale the last few years.
The best starting and pulling for my old Cat D6's burns a 1/2 to 3/4 gal of oil in day. Been using Shell Rotula or TSC brand. But came across a sale on Delo 400 ,tractor burns about half as much per day on it. And that is only adding a gallon to the 4 that is already in it.
So if the idea of mixing brands does not scare you, try different oils it may like one brand better. I have had people tell me of this before, but the first time I ever saw this much reduction.
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Posted: 07 Dec 2020 at 8:25pm
Thanks Ray
