What'd I do wrong,,,? |
desertjoe
Joined: 23 Sep 2013 Location: New mexico Points: 13769 |
Topic: What'd I do wrong,,,?Posted: 03 Dec 2020 at 4:01am |
I tried to post a question in the Farm Equipment section and got a full RED page telling me I did not have permission to post there,,,,WTH,,,?? , SOOoo,,I'll try here,,,
On my D14 Industrial, the engine started to stumble when trying to take off or using the loader or backhoe. It has gotten worse as it goes to where I got to keep it reved up and just "ease" into the shuttle clutch else the engine will die. Any suggestions on what to look at ?? |
DiyDave
Joined: 11 Sep 2009 Location: Gambrills, MD Points: 55278 |
Thanks(1)
Posted: 03 Dec 2020 at 4:41am |
When that happens, go to forum log-in, or you might have accidentally double clicked your post...
steve(ill)
Joined: 11 Sep 2009 Location: illinois Points: 90808 |
Posted: 03 Dec 2020 at 9:19am |
if it runs at the higher rpm, just has trouble getting there.... I think it is the carburetor.. One jet is plugged... Think of an older car with a bad accelerator pump.... You got to FEATHER it to get up in speed, no quick throttle acceleration... ? ............ assuming your governor rod is still attached , and free to move !
Ray54
Joined: 22 Nov 2009 Location: Paso Robles, Ca Points: 4873 |
Posted: 03 Dec 2020 at 10:13am |
Maybe them little green guys NM is world famous for moved into your gas tank.![]() An then one was playing on your computer device. But at least that Nebraski guy that was peeing into gas tanks has been busy building a cook shack, at least that's what he says. ( I need one of the emoticons looking over my shoulder ) Probably just this "new improved" gas now days.
Hubert (Ga)engine7
Joined: 12 Sep 2009 Location: Jackson Cnty,GA Points: 6610 |
Posted: 03 Dec 2020 at 10:20am |
Carb jet plugged or the governor is not opening the throttle when you have a drop in rpm's.
Ted J
Joined: 05 Jul 2010 Location: La Crosse, WI Points: 18967 |
Posted: 04 Dec 2020 at 2:12am |
Tried them idees?? How about vapor lock? Not enough air getting into the gas tank? Sucking air where the carb goes into the intake.
That'll give you something to do for a while... ![]() |
shameless dude
Posted: 04 Dec 2020 at 2:32am |
i would also check what Ted says, check your gas cap vent, do you have a gas filter on it? sediment bowl full of junk or water? check all that then go to the carb. and/or lines
jaybmiller
Joined: 12 Sep 2009 Location: Greensville,Ont Points: 25247 |
Posted: 04 Dec 2020 at 5:35am |
Maybe, just maybe there's a itty,bitty little slivver of yellow gas can nozzle plastic hidden but wedged in the input 'tube' of the sediment bowl assembly ??? I KNOW first hand that'll make a D-14 not 'run right'.......sigh..... at least it was a warm summer day when I lost those 4-5 hours..... Jay
desertjoe
Posted: 04 Dec 2020 at 9:22am |
Well,,I checked the guvner rod and it is free to travel,,guess I'ma gonna take the carb off and go thru it ,,lookin for trash or ,,?? but,,,BUT,,,it been so dang COLD here the last week or so and I ain't got CHIT done outside,, CHIT,,it prolly be better if it DID snow,,at least it have to warm up for it to snow,,!! I been staying inside pretty much as I can only look at Youtube videos for so long. I been catching them videos of oldies but goodies songs and my favorites,,,of Cajun and western musics,,,,,, Chit,,I may even learn some Cajun /french talkin soon,,,,![]() ![]() OH,,and Shameless,,,I just meant that comment,,literally,,you understand????
tadams(OH)
Joined: 17 Sep 2009 Location: Jeromesville, O Points: 11401 |
Posted: 04 Dec 2020 at 1:46pm |
if it's that cold you sure you don't have some ice in carb or gas line
