Model M |
Page 12> |
Tad1991
Joined: 26 Nov 2020 Location: California Points: 10 |
Topic: Model MPosted: 30 Nov 2020 at 2:06pm |
Hello all new here, I just picked up a model M the engine is stuck can’t find number on transmission but engine makes it a 1939. Any parts sources for these? Thanks!!
CAL(KS)
Joined: 18 Sep 2009 Location: Chapman, KS Points: 3804 |
Posted: 30 Nov 2020 at 9:10pm |
Pfouts Family Farm LLC.
Congratulations Norm Meinert After years of providing Allis-Chalmers restoration parts, Norm has decided to retire. Thank You for years of dedication to the Allis-Chalmers community. As of Dec. 1, 2018 all of Norm's parts are available from us! PFOUTS FAMILY FARM LLC. Parts for many Allis-Chalmers Models Specializing in models A, E, K, U, UC, M and Continental Mark and Rosie Pfouts 13040 State Route 700 Hiram, OH 44234 1.440.570.3653 PFOUTSFAMILYFARM@GMAIL.COM Intake & Exhaust Manifolds Waterpumps & Parts Piston rings & sleeves Valve & guides Aircleaner Oil Cups Radiator Cores & Gaskets Brake Bands Amp, Oil, Temp, TB Guages Gaskets & Gasket Sets Full Engine Rebuild Kits T-Handle Gas Caps and Much Much More!!
Dad- WD, D17D, D19D, RT100A, 7020, 7080,7580, 2-8550's, 2-S77, HD15 |
Tad Wicks
Joined: 27 Mar 2011 Location: Shandon, CA Points: 2181 |
Posted: 30 Nov 2020 at 10:56pm |
That M with the PTO looks very familiar to me, was it sitting with an All Crop combine by any chance?
LeonR2013
Joined: 01 Jan 2013 Location: Fulton, Mo Points: 3500 |
Posted: 01 Dec 2020 at 2:11am |
I can't believe how straight it is. Looks real good. For that PTO miner leak I'd try a quart of brake fluid in it and run it for a while, at least run it around until it warms up good. Those old seals dry and get hard over time but brake fluid softens them and makes them swell. Leon
GreenOrange
Joined: 11 Sep 2009 Location: Wisconsin Points: 851 |
Posted: 01 Dec 2020 at 6:57am |
Congratulations on the M - they are a favorite of mine. By appearances, it looks to be in pretty solid condition! Pfouts is a good place to start, as well as placing wanted ads in the classified ads section of the forum.
By some of the features, I believe your M is earlier than a 1939, probably more in the 35-36 range, but parts can always have been changed too. Your M is the wide-tread version too, so when you find the serial number it will begin with a WM. Congratulations again!
Tad1991
Posted: 01 Dec 2020 at 7:23am |
Could be earlier, I found the spot that i believe the number should be, It only has a Y stamped into it. The tractor was sitting kinda in a ditch next to a green fuel tank trailer.
Sugarmaker
Joined: 12 Jul 2013 Location: Albion PA Points: 8661 |
Posted: 01 Dec 2020 at 7:40am |
Tad1991,
Congrats on the M. Friend of mine (Ted) has one with engine issues too.
Regards, Chris |
GreenOrange
Posted: 01 Dec 2020 at 11:42am |
The earliest M's had the serial stamped behind the master clutch inspection cover. Here are the two locations I've seen most M serials stamped. I think I may have seen one with it stamped on the rear of the machine, but it had some very involved attachments including an operators platform. Would love to see more pictures if you have them.
Edited by GreenOrange - 01 Dec 2020 at 11:43am |
knkrein1
Bronze Level Access
Joined: 02 Aug 2016 Location: Gregory, Mich. Points: 74 |
Posted: 01 Dec 2020 at 12:21pm |
So Jake did you move the old M with that Willy's Overland truck? What the year of birth of that truck, I have a 1956 & a 1958 setting in my barn.
Ken R.
Tad1991
Posted: 01 Dec 2020 at 12:31pm |
No number under the clutch cover spot. Here are more pics.
Tad1991
Posted: 01 Dec 2020 at 12:33pm |
It’s a 1948, we used it to pull it around at our place, actually came from same ranch the M did.
GreenOrange
Posted: 02 Dec 2020 at 7:43am |
Thanks for the additional pictures - it sure does look nice. I suppose the main housing may have been replaced at some point, negating the serial number. Would have to go through the features to make a better determination of year. Doesn't really matter though - it's great example of an M either way!
Tad1991
Posted: 02 Dec 2020 at 2:20pm |
Let me know if you would like any pictures of anything specific, the machine was the right price for me at free and isn’t my first crawler, I have caterpillars and internationals. I plan on getting the engine running and it mechanically sound and leaving it in it’s working clothes.
Tad1991
Posted: 12 Jan 2021 at 2:38pm |
Hello everybody thought I’d post an update, got the engine free and turning well. Gonna be putting it back together this coming weekend.
PaulB
Joined: 12 Sep 2009 Location: Rocky Ridge Md Points: 5272 |
Posted: 12 Jan 2021 at 8:26pm |
If your M has a replaced case and no serial number, get ahold of those brothers from Gadsen Alabama and get them to stamp it #1
Just be sure that you get them to do it right side up
Alance
Joined: 12 Apr 2023 Location: Paso Robles Points: 3 |
Posted: 06 Jan 2024 at 8:35am |
I was speaking with mark from pfouts and ordered parts for my m crawler. He then fell off the face of the earth. Any ideas what’s going on or other AC resources?
Alance
Posted: 06 Jan 2024 at 8:36am |
WM5377
Posted: 06 Jan 2024 at 9:35am |
I just recieved a email from him yesterday, reguarding a available parts list for the "M's"
I dont know them personally or at all. I hope they get back to you though, hopefully its just a mix up or whatever. They dont seem like the kinda people who'd do anyone dirty, but im also new here so i really dont know.
everett048
Posted: 06 Jan 2024 at 11:06am |
I was speaking to Mark last night all is well. Just had a big order delivered to the uk.
Pfouts Family Farm
Joined: 05 Dec 2018 Location: Hiram, Ohio Points: 177 |
Posted: 06 Jan 2024 at 4:33pm |
Adam, Have been meaning to call you. I will give you a call!
adamblantz
Posted: 06 Jan 2024 at 9:33pm |
Got a call. Was good to hear he’s ok! Thanks for the replies all.
Tad Wicks
Posted: 18 Jan 2024 at 12:06pm |
Does it have a brazed crack repair on the carb side of the block?
jwal10
Joined: 12 Sep 2009 Location: Falls City Or Points: 66 |
Posted: 25 Jan 2024 at 11:45am |
We had 2 Model M's growing up on the farm. One wide, one narrow. We overhauled the narrow's engine. In the end we used the wide one for parts. We liked the narrow to log with and it had a small winch. They were sold at the farm sale in 1980, 1 running, 1 parts....James
Edited by jwal10 - 25 Jan 2024 at 11:45am |
adamblantz
Posted: 26 Jan 2024 at 5:30am |
I don’t think so. Mine was owned by famous zin grower Richard Suaret
Tad Wicks
Posted: 28 Jan 2024 at 1:09pm |
The only reason I ask is because I looked at a Model M back in the 80's over the hill in Sunflower Valley on Hyway 41 on the way to Fresno, as I remember it had a PTO like yours and I think some kind of hydraulics for the All Crop sitting next to it. I took a trailer to bring it home but the engine was stuck and there was a sizable crack in the block and so I decided not to buy it, I regret that decision. There was a McCormick Deering 10-20 sitting there as well and try as I might, it was not for sale. I don't know what happened to any of them. It just peaked my curiosity when I saw the PTO unit on yours, there couldn't have been very many of those around here and they were probably used to run All Crops, one of the very few PTO possible combines of the day.
FarmerChuck
Posted: 22 Mar 2024 at 11:59am |
Purchased a Model M. Don't really need another project, but ""price was too good" to pass up
!! New to forum. Is operator, service or parts manual available free on line? Can purchase manuals from Jensales or others, but have found free access in past to Mercedes Benz, Chrysler and some others.
Is there a group or whatever specific to M/WM (or U/UC for engine) here somewhere? I am not good with forums, searches, posting and the like. Should I start a new topic for my project specifically? Thanks in advance for any help/advice |
adamblantz
Posted: 23 Mar 2024 at 4:44am |
mine doesn’t have a pto or cracked block and don’t think i posted a pic would like to but not sure how to do it. I got the engine running and a new radiator. Despite the rebuild kit for the carb that i got from Pfouts, it’s not being a good team player. You think that one on 41 is gone? I am in Paso Robles so thats not too far. Any recommendations on other carbs that might work? Or carb guy to whip it into shape? My mechanic thinks i should ditch the project but i am invested and stubborn.
FarmerChuck
Posted: 23 Mar 2024 at 11:17am |
Description of problem(s)? Hard to start, rough idle, won't run smooth at higher RPM Intermittent misfires, loading up (too rich), runs then dies, runs but low power, etc? Sure fuel supply is good: fresh fuel (Nonethanol premium or aviation fuel worth it for trouble shooting, I think), no contamination from tank/sediment bowl, good flow, carb bowl filling properly? How does Adjusting idle and main jets change way it runs? Ditto moving choke.
Are you sure governor and throttle rod (passing thru block from right side) are moving carb butterfly as they should? Have you tried judicious use of starting fluid? Remove air cleaner connection so you can work directly at carb intake if not already doing so.
Are you confident your carb kit install is "right"? These are a very simple carb, but still a carb so number of ways it can "not be a team player"!! You gave it a good soak/cleaning with carb cleaner and compressed air before rebuild, correct" Lost count number of times I have worked on fuel (carb, etc) problems only to discover Ignition was biggest issue, and vice versa. And have had both, which is really a pain to diagnose. |
Many Projects, too little time! AC Model M dozer with winch, MF40, MF35 Utility, IH 606, Fordson Super Dexta, Fordson Super Major, Pettibone Super 8
WM5377
Posted: 23 Mar 2024 at 4:44pm |
Im fairly new as well but also working on a "M". Not sure on the manual being free online but it is pretty cheap if I remember correctly. Haven't found any specific group on the "M" Im also not to familiar with forums but have been posting some of my progress. It seems like its the norm to make a post about your project ect or any advice ect. Don't have much on advice but there are a few others on here that know alot more about the "M"s and also about the forum. Good luck look forward to seeing your post/ project. If you wanna check mine out its currently under the 'Allis "M" radiator rebuild' post.
FarmerChuck
Posted: 23 Mar 2024 at 7:37pm |
Manuals are pretty cheap: Operators, Service and Parts set $55 PDF, $141. Paper (Jensales). Not certain the set covers my engine/vintage, but apt to be big help. I have seen your "Allis M radiator rebuild". Impressive work! I am really hoping my new purchase does not need this level of reconstruction!!
Appreciate you taking time and effort to do such a good posting. Check out Farmer Clay Allis Chalmers M Restoration YouTube if U haven't yet done so.
Page 12> |
