Wanted Manifold Leroi power unit
CTALLIS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTALLIS Quote  Post ReplyReply Direct Link To This Post Topic: Wanted Manifold Leroi power unit
    Posted: 22 Nov 2020 at 11:19am
Need a manifold for a Leroi power unit with a 201 engine
d17turbo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote d17turbo Quote  Post ReplyReply Direct Link To This Post Posted: 08 Dec 2020 at 5:51pm
I may have what you are looking for. Does the exhaust on the manifold exit out the front insted of the center ?  My manifold is bolted to what appears to be a wd head. However the valves are recessed , not flat like a wd. let me know if this helps. Glenn
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 08 Dec 2020 at 6:26pm
I believe that would be a bonified LeRoi cylinder head and manifold. The cylinder head looks very much like a WC/WD until you turn it over.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTALLIS Quote  Post ReplyReply Direct Link To This Post Posted: 10 Dec 2020 at 10:34am
sent you a PM
