F/S Gleaner E Engine |
Post Reply |
CJohnS MI
Orange Level Joined: 27 Jun 2010 Location: Lapeer MI Points: 326 |
Posted: 02 Sep 2010 at 11:44am |
Pulled from a WD 45 & still has clutch housing on it. Can hear run. Starts easily, no smoke, no noise. $850.00
This is a friend's engine. He/we got this because the WD he rescued was in baskets & at the time, the WD engine didn't look too hopeful. Since then, we've gotten the WD running, and THAT engine is excellent too, so this one is no longer needed. PM me, and I'll give you the seller's ph# soz you can deal direct. Thanks, John PS: Oh BTW, if I can talk the friend into it, that WD NF may be for sale as well. Has spanky new rebuilt head (valves, seats, stems, etc) engine runs strong, metal is very straight, but tractor has a lot of field time on it. |
CJohnS MI
Just started it and ran it up for a couple of minutes.
The serial number is: 17-72067-Z The Z suffix means its the later, higher compression engine. "Later Gleaner E's and all EIII combines had "Z" engine codes with 8:1 compresssion." Mechanical fuel pump opening already has a block-off plate installed. Also has the full flow oil filter. Includes starter, carburetor, distributor, everything needed to hear it run on the pallet. Edited by CJohnS MI - 05 Sep 2010 at 1:52pm |
Post Reply | |
